Does anyone have any experience with removable baseboard for each of access to cable channels.
Wiretracks looked like an excellent option. Basically a two piece box with two U channels that snap together and apart. One is drywall depth where the cable lives and the other attaches to whatever baseboard you want to use. Problem is they are out of business. It would be possible to fabricate something but would likely be more complicated and expensive. None of the other raceways I've seen are too deep, too shallow, curved instead of boxes, meant be be outside of baseboard, etc.
Any thoughts.
http://www.wiretracks.com/prod-rf.html
Any thoughts.
