My low hour Marquee 9500LC's green tube went bad few days after installed the new Moome's V3 HDMI card
, The green tube still on but is very dim. and if look into the tube from the front PJ (with video signal fed) there is sort of un-sync white noise floating on top of green backgroud, while the red and blue still have a normal video signal.
Take advanced of Moomy board on sale at Kurt web side before Christmas. First day install the board seem working OK on most of HDMI sources but very greenish with Netflix video, then later find out need to set to Auto Detect Input Color Space and all seem work on that day..Well next evening, turn a 9500LC on...green tube gone..I means gone since all the Marquee menus displays on green characters.. now just the bunch of black empty boxes
Have this Marquee for over 8 years and used RGB sync connectors most a time last time I check there is about <1500 hrs. Anyway I have a set of spare tube (bought here few years back) and plan to retube the green one in week-end. BTW I have been re-sitted all the connector, inf boards, yorks which I can access when removed the top PJ cover(invert ceiling mount) but no diff.
Boy I'm getting old to bring down the PJ from my ceiling..So if anyone have a clue or experienced about this problem please give me the hints/pointer. Oh you're also save a back of the old man
, The green tube still on but is very dim. and if look into the tube from the front PJ (with video signal fed) there is sort of un-sync white noise floating on top of green backgroud, while the red and blue still have a normal video signal.Take advanced of Moomy board on sale at Kurt web side before Christmas. First day install the board seem working OK on most of HDMI sources but very greenish with Netflix video, then later find out need to set to Auto Detect Input Color Space and all seem work on that day..Well next evening, turn a 9500LC on...green tube gone..I means gone since all the Marquee menus displays on green characters.. now just the bunch of black empty boxes
