Hi, I came across an interesting problem and was hoping for some help. Sorry for the length. To summarize, the issue is that when trying to replace a splitter I can feel a mild shock on one length of cabling and touching the splitter.
About a week ago AT&T Uverse stopped working on my Mitsubishi 60638. The Uverse box could not connect to anything. I tried rebooting, etc., but found the real problem. The cable from the wall plate to the surge protector was bad(a red plastic ring at the end looked melted). Also the wall plate itself looked like it had been hit with a surge(the plastic in the middle looked a little melted and the end was a little black).
This was the only sign of a problem in the house. The other tv's and surge protectors seemed to be working fine.
I went out and bought a new surge protector and wall plate(I had an extra cable laying around). After replacing the wall plate I was able to plug the cable from the Uverse box directly into the plate and everything worked fine. I did not immediately plug the cable into the surge protector.
While going through this I realized that the Uverse installer had kindly given me a 4 way splitter instead of the two way one I needed. I was hoping to improve my signal strength and tried to replace the splitter. The input was fine and the first output was fine, but the second output which leads to the Mitsubishi box with the problem mentioned above, gave me a mild shock.
After much checking on things, it only seems to occur when the tv is on, or is in the lengthy process of shutting down. Even with the Uverse box unplugged it seems to get a current through the HDMI connection that then continues through the cable to where I am connecting the splitter. When I plugged the cable into the surge protector that issue seems to have gone away.
My questions are - am I damaging my other components hooked up through HDMI? Is this something that I need to get fixed on my tv? Is this a Uverse issue, HDMI issue, Mitsubishi issue, or an issue with wiring at my house?
Any suggestions or ideas are greatly appreciated.
