AVS › AVS Forum › Video Components › Home Theater Computers › win7 default audio keeps changing...
post #1 of 2
for some reason the default audio output i set up in windows7 Sound config keeps changing to something else every time i reboot...
why aint it sticking and how can i make it stick to what i want !?!
edit: i'll just try this: i disabled everything else but spdif out lets see what else its going to switch to ...lol
post #2 of 2
This happen to me last year. You need to reinstall or update the audio driver, it's that easy. I assume you have onboard audio (realtek?) I'd go to the motherboards website and download the latest. If you are upto date, uninstall then reinstall. Hope this helps, Good luck. Thanks
