My brother-in-law has a BenQ, and it just didn't do it for me. He actually doesn't love it either, and is looking to swap it out.
2) Stewart is cosidered the reference but yes you do pay for it. Never owned a Stewart, but Dennis Erskine uses them so they must be good. If you've got the money then that's what I would get.
Yeah, they must be great screens -- but the price increase is hefty!
3) Overkill is a term that you should erase from your vocabulary. But no, separates would not be overkill. Once you make the jump from an AVR to separates, you'll never go back. If you're looking to purchase Klipsch THX Ultra speakers, then an AVR will simply not suffice
4) I'm an M&K fan myself. Not sure what the budget is, but I've never heard anyone say anything negative about them. My neighbor actually prefers my M&K THX select system to his Monitor Audio Silver Series. M&K is the brand of speaker that was used for mixing at least one Star Wars movie and many other big budget films so I will definitely recommend giving them a listen. I'm sure Moggie can tell you all about the Klipsch THX speakers and I'm sure they are awesome even though I've never actually heard them.
The design is now veering back to free-standing speakers and the Klipsch are high on the list. I will need to look into the M&K.
