Originally Posted by kgveteran
So, why not bolt the speaker to the hole where it ususally drops in. No question you can brace the box front to back, side to side, top to bottom...with no attention to the basket protruding to the inside of the cabinet.
So wiring it out of phase and firing out through the basket as its primary direction isnt a problem....
youd have to weigh down the other side of the box like crazy to keep it sitting flat. Just one point, at least for this particular build, smaller drivers, the bracing wont need to be as articulate anyways
. Back to OP and bracing....
