AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › The workings of an LCD monitor
post #1 of 4
Hello
I have some questions as to how a standard LCD monitor with a cfl backlight works under different circumstances. I understand that a monitor can generally display 256 * 256 * 256 colours of red, blue and green based on the amount of power supplied to each sub pixel. But what I would like to know is what actually physically happens upon changing
1: The color temperature
2: The brightness
3: The contrast
Is it just a case that these change the strength of the backlight and the intensity between 0 and 255 of the sub pixels or is it more complicated?
This would be really useful to me
post #2 of 4
CFL TV does not change backlight intensity dynamically, you can adjust it to desired level, but once done it stays that way regardless if the scene is dark or bright. You need LED backlight for dynamic changes in light level depending on the scene. What changes during video display is the amount of twisting of LCD crystals, depending on the voltage applied, more voltage, more twisting towards 90 degrees, more backlight passes by towards the viewer, brighter the picture (actually you can have design where crystals are aligned to block all light with 0 voltage and open up with voltage, or be open with 0 volts and twist to close light with voltage applied.) The amount of that crystal twisting needed to display picture properly is calculated by video processors. Lets say digital video signal comes in and calls for medium gray:128,128,128. So now video processor looks at your calibrated settings and adds offsets to each subpixel to keep it gray (lets say your colors were too red so you added some corrections) so now the numbers are 100,135,115 and it's translated into proper voltages, send to crystals to twist proper amounts, so you see gray. The same way processor adjust for contrast, color and brightness by adding proper offsets to each subpixel. To keep it as simple as possible I'm not going to go into color dithering and other aspects of additional video processing.
post #3 of 4
Perfect just the kind of concise answer I was looking for.
Many thanks
post #4 of 4
You're welcome
