Originally Posted by Puwaha
I don't want to belittle people's concern for electricity use... if it's done in the name of conservation. But the difference between a CPU that uses 65 watts TDP versus one that uses 95 watts TDP is miniscule in the grand scheme of things.
Say your electricity cost is $0.09 per KWh
i3-21xx at 65W TDP for a years worth of electricity is $51.25
i5-2xxxK at 95W TDP for a years worth of electricity is $74.90
A difference of $23.65 per year! That would require 3.3 years of constant use from your i3 to make up the power/cost difference... and this is all at maximum wattage ratings for the CPUs. The CPUs are not maxed out 24hours a day 365 days a week.
I only pay $0.06 per KWh in my area which makes the electricity cost/difference even less... $15.77 a year. That's 5 years!
Not all of us are lucky to pay that little for electricity. In my area we pay $0.19 per KWh. I calculated the savings over my old servers compared to using a G530 and I will be saving over $100 a year per machine.
If you *need* the extra processing power, then go for it. If you don't, you are just heating your house.
