Hello...
I've been using a set of Logitech Z-640 computer surround speakers, for years, through the on-board Realtek ALC883 analog outs.
My first home theater receiver will be arriving in a couple of days and I don't have a clue what the best way to send sound to it is.
My first thought was to send optical from the mobo to the receiver, but I realized a couple days ago that my mobo doesn't have digital outs (I would have said it did, if you asked).
I have a radeon 4830 with hdmi out (I'm sending vga to a projector for custom resolutions, so the hdmi is unused).
I was planning to go that route, but then I read something about hdmi only sending 2 channel pcm and dts (I watch a lot of ac3/aac/etc... that I want to make sure stays in true surround).
A lot of that information seemed to be from the mid-2000s, though, so it may not be relevant.
I have an old Via Envy24HT-S pci card from a previous htpc that does have optical.
Maybe optical out of the envy24 is the best option, but if it has the same spdif limitations of the hdmi, then maybe straight analog is better.
Also, I'm not really sure whether the realtek or the envy24 would have better dacs, for the analog.
My understanding is the envy24's dacs were so-so, but I assume the realtek ones are equally so-so (although, maybe 5 years of so-so improvement is better).
So, given my mixture of audio sources, which would be the best means of getting audio to the receiver?
Again, this is my first jump into more "home theatery" sound so please excuse me if these are pointless questions.
Hehehe...
My logitechs have served me very well and made things very easy for a long time.
JJ
Edit...
A couple things that may be worth noting...
I run windows xp and use XBMC, generally, for watching movies and listening to music.
If XBMC isn't playing full speed (dxva doesn't seem to work - I may just need to configure some things), I use MPC-HC (dxva works just fine, there, but I had to configure some things).
I just noticed XBMC not keeping on a movie, for the first time, yesterday.
JJ
Hehehe...
JJ
Edit...
JJ
