I've done lots of research but still cannot pick something out for my new house.
I currently have a 65 inch samsung plasma flush against a wall in a fairly large room.
The room side is 14.5'w x 21'd x 10'h. The seating position is 18' away from where tv is positioned. Wood flooring. Cut out for kitchen is 10'd x 5'h for the most part.
My biggest problem is the size of my built in shelf for my center speaker. The dimensions are 18"w x 8"h x 2ft deep for center speaker which causes some problems for bang for buck speakers that are usually recommended like Polk Monitors and Energy towers.
I currently have Klipsch rw-12d and Pioneer vsx-1121-k. My viewing breakdown is 45tv/45movies/10music. The room is a living room and not a home theater so it doesn't have to be 100% optimal. One day ill renovate my basement and hopefully have a dedicated home theater room, but this might have to do for 3-5yrs.
Any help would be greatly appreciated. My center space is becoming a real problem in deciding on what to buy. My current budget is $800-1000 for the 5 speakers since I already have a sub. If there is a great option in the $800-1000 range for just left center and right, I may go that route so I can spend a bit more on the 3 speakers and Ill get some surrounds afterwards (Ill keep some crappy HTIB speakers for surrounds.
Again, looking to pull the trigger in the next 2 wks or so on speakers so I am looking for serious help. Thanks. If you need any more info let me know. All suggestions are appreciated.
Which is not a problem when you run all the same or similar speakers.
