Hello,
I have been reading on various forums for a few days now and I don't know if I have run into a case of paralysis by analysis or not. I have an old Sony HT Receiver hooked up to my Record Player and a MP3 player. It is continually cutting out. I can firmly press various spots on the front panel to get it to kick back in, but it is truly annoying.
Anyways, I have been look at the HK3490 and the TX-8050 as a replacement, since I am not using any Home Theater functions (as I won't ever have a TV set up in that room) I figure a Stereo receiver is a better choice. Is this a valid train of thought, or are there AVRs out there in the same price range I should consider even though I am only hooking up two speakers for the forseeable future?
With all things equal, is the potential quality of sound produced by these two receivers going to make most folks happy? Am I overthinking this? Is it likely that either receiver is a good choice?
I probably would like the networking features of the Onkyo, but I could work around that with my MP3 player or even a network media player (like a WDTV or Popcorn Hour) and a small monitor. If the HK was that much better, I would probably just go for it since it is a little cheaper.
Build quality and life expectancy of either unit has spooked me into looking for an extended warranty, so I am not sure those qualities would lead me to one or the other.
Anyways, I appreciate you taking the time to read my post. I am curious to know your opinion.
Alex
Alex
