Hello all!
I am in the market for a new flat panel TV/monitor to replace my trusty yet ailing Toshiba 30HFX84 HD CRT. I have a set of requirements that has proven difficult to shop for. The short story is that I'm looking for a 32" or 37" display with the best image quality possible (I have strict space constraints in my viewing environment, but having cut my teeth in broadcast and d-cinema, I'm finicky about picture). The long story is as follows.
Need:
Want:
Don't Care at All About:
PRICE: Flexible, anything under $1000 would fine. But honestly, I could talk myself into overspending if the performance is there.
So you see my problem. TVs/monitors that cater to my "wants" are few and far between, especially in this size range. Any thoughts?
Thanks in advance! I will be sure to keep this thread updated with posts on my own research and progress.
Need:
- 32" or 37" diagonal screen size
- Advanced color calibration controls/ability to produce and hold the best possible color calibration
- Better than 6-bit panel (color resolution is a huge thing for me)
Want:
- 1080p resolution
- Deep, rich blacks
- Ability to correct gamma (or at least, have it roughly correct out of the box)
- No major ghosting issues
- Ability to fully deactivate any motion interpolation/edge enhancement/other sorts of ill-advised processing garbage that seems to be endemic to modern displays
- 3D. However, I will consider a 3D capable set if it happens to also have better overall 2D performance than its 2D-only counterparts.
- "Smart" TV features, streaming video, DLNA, etc (between my Xbox 360 and my HTPC, I'm well covered in that area).
- Audio Performance (a Denon AVR-1712 and a 5.1 channel B&W 603 set are handling audio duties).
- Performance with Standard Def and interlaced video (I don't watch cable).
- Similarly, TV tuner performance. Won't be using it.
- Panel Depth, Power Consumption
) But, unfortunately, black level isn't deep, as it's S-IPS(for me personally, black level is "O.K" with some ambient lighting).
