I was hoping I could get a little help on a subwoofer hum issue. The sub is a Polk PSW505. Up until yesterday I had my subwoofer sitting in front of my TV stand, connected with a cheap, VERY thin, 6' composite cable. It was only a temporary setup until I could route a cable up the TV wall, thru the attic, and down the back wall. This would allow me to place my subwoofer on the back wall where I have room for it.
So yesterday I finished running the wire, which was a huge PITA. It's approximately 60' long. It's a solid copper RG6 tri-shield (60%) coax with RCA compression connectors I got from Home Depot. They are DataShark brand. I get it all hooked up. With everything connected and the receiver off, I can hear medium volume hum if I turn the volume up to 100% on the subwoofer. It was something I didn't recall hearing with my temporary setup.
I then begin experimenting with all sorts of configurations. I first bring the sub back next to the receiver and use the cheap store-bought composite cable and listen for a hum. There is a very faint hum with the sub volume at 100%, but you almost need the house dead silent and your ear just inches away. Out of curiosity I made a 6' cable with the RG6 coax and HomeDepot/DataShark connectors and the hum was no different than the cheap store-bought composite cable; VERY quiet hum.
So then I decide to isolate the sub from the receiver. With power to the sub and the 65' coax cable connected to the sub, but NOT to the receiver (this end just loose, laying on the ground), it makes the same medium level hum at 100% volume. As soon as I remove the 65' coax cable from the sub the hum gets so quiet, it's almost nonexistent. Same goes with the 6' store bought composite cable. As soon as I remove the composite cable from the sub, the hum goes from vary faint to almost non-existent.
Do you think the cable is picking up interference along with length? It just seems the longer the cable I attach, the louder the hum.
I know there are hundreds of sub humming threads on here and I read many, just couldn't find a solution that worked for me. Based off what I saw in other threads, Im going to list a few things ahead of time that may be asked. I do not have cable or satellite. I have an OTA antenna in the attic. The receiver and sub have 2-prong power cords. I think they are on the same circuit, but will need to confirm this.
Ideas? Thanks!
Ideas? Thanks!
). An easy check is to use a cheater plug on the sub and see if the hum goes away. If so, you can leave the cheater and take the shock risk (I have, since I rarely shower whilst handling the sub), or get an isolator to separate the grounds.
Could still be a loop, but reading the OP's post again I am not sure the hum is there when the AVR is on?
