the arms will pull out from the wall frame past your cabinet , when placing the display frame on the arm frame as long as the arms are fully extended it will be easy, with slide feature the centering will be easy as well . critical part with be the up/down centering , & 3 guys will be great as one to be the watcher to see how the attachment point lines up & advises up/down/right/left to the 2 guys doing the hold/liftingOriginally Posted by xDeLiRiOuSx
I had a feeling I left something out! The cabinet is 24" deep.
I did some quick research and found out that the XF228 fully extended to 28"... That should perfectly clear it.
Wow, now I'm really gald I got the XF228!
Thanks for your responses, Mike, it's been very helpful!
I had just me & a buddy & it took about seven tries to get near the attachment point , the thing snaps & locks with a inward/ then down movement
The coupon is gone, but it looks like the $3399 deal is still on!
