AVS › AVS Forum › Audio › 2 Channel Audio › I am confused, how to store high SQ music and playback into 2 channel system?
I am confused, how to store high SQ music and playback into 2 channel system? - Page 4
post #91 of 107
Then instead of "realizing", some of the participants are unable to hear a difference in the non-blind test.
There's no such thing as a non-blind test. In a blind test, the question is, "Are they the same, or are they different?" In a "non-blind test," you'll know the answer to that question before you even start listening. That's not a test.
I think what you're trying to say is that people who listen sighted will sometimes conclude that two components sound the same. But so what? That doesn't mean anything. In fact, it doesn't even mean that they would be unable to distinguish the two components in a blind test!
You want to use the fact that people sometimes don't hear differences to prove that people are capable of controlling their biases. But it might be that the people who claim to hear no difference do so because of a pre-existing belief that they won't hear a difference. Bias can work both ways. And whichever way it works, you can't turn it off. You can only control for it.
post #92 of 107
Originally Posted by cel4145 View Post
You are right. I was over thinking it in response to what ccotenj said, that no one can control their ability to be influenced by bias.
I suspect that there are people who can control the influence of their biases some of the time. The problem is then knowing when they are sucessfully doing that!
But there are likely some people that, in the 2nd test, will manage to over come the influence of seeing A and B and realize that they are indistinguishable.
I've done 100's of blind tests and never seen any evidence of such a person actually existing.
post #93 of 107
How can an opinion be anything but subjective, and thus biased
Ever heard of unbiased opinion? The process to extract it would differ.
post #94 of 107
"Unbiased opinion" is some ways a misnomer. One might not be subject to a particular bias which is under scrutiny and most relevant to a decision where an unbiased opinion is sought (in that sense it is unbiased), but it's still subjective, based on the sum of the experience of that individual, and thus subject to other biases that cannot be accounted for.
post #95 of 107
Wow. That's interesting. If that kind of research has been published, seems like it addresses the whole issue of this internal discussion in this thread.
post #96 of 107
Which real life example are you talking about?
post #97 of 107
Wow this discussion has taken a heated and unexpected turn! I must admit that I do not know enough about double blind testing and bias problems but my beautiful wife is sitting next to me reading a book, and being that she has a graduate degree in psychology and has done actual research in the psychology field for her work in the doctoral programs, I thought I would ask her about bias. According to her very short response, there is bias in just about every person on this planit in one way or another, and judging from her facial expressions, it seems to be a lot more complicated than that.
post #98 of 107
Anything and everything.
post #99 of 107
Strawman argument.
post #100 of 107
Interesting. My wife also has a degree in psychology and had a lot to do with the statistics that we used to analyze ABX tests back in the 1970s and right up until this day. Sounds like you have a "keeper"! ;-)
post #101 of 107
You seem to be underestimating the problem. I would say that "unbiased opinon" is an oxymoron. Bias is so much a part of the human experience that even "unbiased fact" can be doubtful.
Bias is so much a part of the human experience that even just estimating which biases are stronger or weaker can be very challenging.
Saying that someone is not subject to a particular bias is very questionable, unless the experiment is structured so that every known or reasonably hypothesized bias is reduced to vanishing levels.
For example we invented procedures and equipment for doing audio DBTs fairly easily, only to be criticized on the grounds that we had introduced far more serious biases with those procedures and that equipment.
Once we started doing audio DBTs and got some visibility for them in the audiophile press, either coincidentally or as a result of them, audiophiles started becoming very vocal about alleged sonic colorations due to cables and switches and relays, which were inherent in the equipment we developed.
The bottom line is that hope springs eternal, and telling people that they have just bought a truckload of whole cloth is likely to be met with a lot of emotional resistance.
post #102 of 107
Well, it depends on how you define "fact." If a definition of "fact" recognizes that all knowledge is socially constructed, then maybe not because the fact is representative of shared meaning. But on the other hand, from a Derridian perspective, the meanings of all words are shaped by our experiences and change subtly through ever utterance or time we read them. Reading this paragraph has changed the meaning of "fact" to anyone who reads it from what it was before this paragraph was read.
And I now I think I've crossed deep into humanities land from the scientific experimentation concepts that this thread for dealt with
post #103 of 107
From some discussions on an Apple forum it appears that Airport Express can only handle 44.1 and 48K. In principle 44.1 is good enough for CDs. However I would prefer an actual computer, where you can get 96, and you have more control over what's going on. I normally run my computer audio feed to my receiver or DAC at 96. (I have one of each: a Mac Pro going to an Arcam receiver, which does the DAC function, and a Macbook Pro going to a Benchmark DAC-1.)
My music is almost all Apple Lossless ripped from CDs.
post #104 of 107
Most CDs are 44.1. Best to rip to them that and then play them back at that, too. Otherwise, there can be some minor sound degradation in the conversion to 96.
post #105 of 107
All CDs are 44.1. Unless there's something wrong with your system, upconverting them will be audibly benign, but also pointless.
post #106 of 107
See, I've read with PCs that's not always the case, that there can be audio signal degradation depending on the setup when upconverting. Maybe Macs are different
post #107 of 107
That's what I meant by "Unless there's something wrong with your system..."
