Originally Posted by
InfernoST
I beg to Differ. If you look at the page in the manual the *2 denotes does not play file format on DLNA server.
Mp4 is tricky because its a format AND can be a container.
You do need to first figure out what the video and audio codec used for the file is ... and then you can go from there.
As an example the podcast HDNation from Revision 3 is a "mp4" file. The file is being served by "playback DLNA" for mac. It has no transcoding ability.
The S790 "sees" the file as a MP4 and can play it.
On closer examination of the file, the video codec used is AVC Mpeg4 and the audio is AAC.
General
Complete name : /Media/iTunes/Podcasts/HD Nation (HD MP4 - 30fps)/Best HDTV At CES Wasn't 4K. Panasonic ZT60. Broken HDTV_ Here's what to do first! CES Highlights_ HD Projectors, 4K, IGZO, Sony, and Boom Boxes_!_ - HD Nation.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 117 MiB
Duration : 8mn 37s
Overall bit rate : 1 897 Kbps
Movie name : Best HDTV At CES Wasn't 4K. Panasonic ZT60. Broken HDTV? Here's what to do first! CES Highlights: HD Projectors, 4K, IGZO, Sony, and Boom Boxes?!? - HD Nation
Album : HD Nation (HD MP4 - 30fps)
Performer : Revision3
Genre : Podcast
Recorded date : UTC 2013-01-18 17:00:00
Encoded date : UTC 2013-01-17 02:26:54
Tagged date : UTC 2013-01-17 02:26:54
Writing application : Lavf53.32.100
Copyright : 2013 revision3 corporation
desc : / You know there was a lot of amazing HD gear at CES this year... Robert's talks Panasonic ZT60, Digital Projection HD projectors, light sensor pens, 4k, OLED, Sony, IGZO, the latest trend in Blu-ray player design and... boom boxes? Broken HDTV? Learn from
plID : 323878308
pcst : 1
purl : (Binary)
egid : (Binary)
ldes : / You know there was a lot of amazing HD gear at CES this year... Robert's talks Panasonic ZT60, Digital Projection HD projectors, light sensor pens, 4k, OLED, Sony, IGZO, the latest trend in Blu-ray player design and... boom boxes? Broken HDTV? Learn from Joyce and call the manufacturer first! /
cnID : 0
rtng : 0
atID : 0
cmID : 0
geID : 0
sfID : 0
tvsn : 0
tves : 0
stik : 0
purd : 1904-01-01 00:00:00
rndu : 0
rpdu : 0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 8mn 37s
Bit rate mode : Variable
Bit rate : 1 800 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.065
Stream size : 109 MiB (93%)
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=0 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=180 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1800 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=1890 / vbv_bufsize=12000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 8mn 37s
Bit rate : 117 Kbps
Maximum bit rate : 160 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 7.23 MiB (6%)
Language : English
So as mDaveJ points out above, the table Sony sent you is incorrect as the 790 can play AVC mpeg 4 video with AAC Audio (mp4) over DLNA without any trans-coding.
And yes, that table is so screwy. NO DTS on a M2TS over DLNA? What are they on. Of course that is supported. Not just DTS, but DTS Master Audio too.
Hahaha, Sony marketing are not talking to Sony engineering.
Edited by apw2607 - 1/30/13 at 2:30pm
