AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official 2012 Sony BDP-S790 Thread
Official 2012 Sony BDP-S790 Thread - Page 82
post #2431 of 3485
Originally Posted by hoopmanjh View Post
Anyone have any recommendations for a USB drive to stick in the back of the 790? The one I'm trying to use keeps coming up as "Unrecognized" and I think it's causing squirrely behavior in my player. I'm not using it for content purposes; just to give the player some memory.
I like these
Verbatim Store 'n' Stay 4 GB USB 2.0 Flash Drive 97462 (Black)
by Verbatim
http://www.amazon.com/gp/product/B004BLIQE6/ref=wms_ohs_product?ie=UTF8&psc=1
post #2432 of 3485
I like those apw. there are so many of these thumbs out its difficult to choose. and how big do you need of a thumb drive? is 8gb enough? decisions decisions... rolleyes.gif
however i have these
http://www.staples.com/SanDisk-Cruzer-Facet-8GB-USB-20-USB-Flash-Drive-Orange/product_105553
and i can verify these work just great on the 790 and the 5100
$8.00 for 8gb
shows OOS online there (could be just that color) but just this thursday I picked up two of these to replace the spinning drive (Lacie) i had on the 790 and to get an additional one for the 5100.
Edited by marctronixx - 3/18/13 at 1:15am
post #2433 of 3485
I use this:
http://www.sandisk.com/products/usb/drives/extreme/
....16 Gb and formatted NTFS.
post #2434 of 3485
Does anybody have a recommendation for a better way to type in the texts without using the remote??? A wired/wireless keyboard, or maybe a sony app for smart phones???
post #2435 of 3485
You answered you're own question. Yes, to both you're answers .. although wireless keyboard may be tough.
Sony's Mediaremote for iOS and Android supports keyboard entry for everything other than VUDU and Netflix.
Wired keyboard supports all text entry (even Netflix and VUDU).
post #2436 of 3485
i use my motorola xoom tablet to enter text.
post #2437 of 3485
Thank you for a quick reply.
I read it somewhere that one could use a wired keyboard. Haven't tried it yet. But I much prefer the wireless one, so that I can do the text from the sofa a few yards away. But I have to try Sony mediaremote for iOS. Wish they make it work with Netflix 'cause its my major streaming site.
post #2438 of 3485
I assume you use the same Sony app mentioned above?
post #2439 of 3485
The wired works fine, I will try my wireless after work today.
post #2440 of 3485
I should also mentioned tv sideview app also supports keyboard entry.
post #2441 of 3485
post #2442 of 3485
Hello everyone, I have read every line of all 82 pages. Wow, what a thread.
Based on your comments, thoughts and results I purchased the S790.
I am truly pleased with this product.
I do have two issues that I will toss out there in hope that one or two of the experienced end users here can offer a solution.
First, I am connecting to a Denon AVR 3806 and a Mitsubishi DLP. I split the signal using HDMI 1 to the DLP and HDMI 2 to the Denon.
The sound and picture are fantastic (Blu Ray, DVD etc...) however, while playing SACD I only get a stereo (2CH) signal. I have attempted many different setups but just can't make it happen.
(My Denon 3910 plays SACD well so no emergency there) but I would like to have a backup in place.
My second issue is with DLNA. While my S790 streams well with netflix, pandora, etc... using my wireless router connection through verizon FIOS, I can't seem to get a connection using Sony's homestream software which seems identical to serviio. (I tried serviio as well, no luck) I would really like to be able to play files from my computer over my Home Theater system.
To be honest, I am rather new to the digital streaming method and am trying to learn on the fly!
Thanks for any help that comes my way. You guys are a wealth of information.
Frantic
post #2443 of 3485
Just as an FYI to everyone -- I pulled the USB drive out of my player this morning, and the problems I'd been having (primarily failure to connect to Netflix and incredibly long load times on some discs) seem to have vanished completely. The new drive should be arriving today, so we'll see what happens when I plug that one in.
post #2444 of 3485
Originally Posted by Iain- View Post
I've had BDP-S790 for several months, but never use it for DVD.
I was reading in blu-ray.com forum yesterday, where S790 will output 24 hz for film-based DVD. Is this correct or is this simply a Sony Marketing ploy?
If it will output 24 hz, what player configuration is required for this?
Sure, just set DVD 24p output in settings to Auto or On ...
This worked well. Thanks for the information.
I had player set for "Original Resolution" for BD, but had to change it to "Auto" for DVD so it would up-scale to 1080/24p. Depending on media quality, BD look better on my system when playing direct from disk.
Reckon I'll have to change it for each media type, though.
Edited by Iain- - 3/20/13 at 11:07am
post #2445 of 3485
Why did you set it to original resolution for BD? Not sure I see the point, when most BD is 1080p - right ?
post #2446 of 3485
Frantic
Under Music settings, select SACD playback channel = DSD Multi
2nd setting depends on if the AVR 3806 supports a DSD signal over HDMI. If it does, then under audio settings set DSD output mode to ON. If it doesnt support DSD native, then set it to OFF. The S790 will then pass multi channel PCM over HDMI to the 3806.
As far as not seeing Serviio or Homestream, in the Serviio/Homestream server console, do you actually see the Sony S790 appear, shown as Bluray disc player. Is it on the same sub-net ?
post #2447 of 3485
In addition, set the AV Separation Output Mode to ON. I had a similar problem and talked with Sony, which was really useless as the person I talked to did not seem to understand what DSD was. I have HDMI 1 connected to the TV and HDMI 2 connected to the receiver. While I was on the phone I realized that I had the TV on. Turning off the TV resulted in magic - the receiver recognized the input as DSD. Turning on the separation mode allowed the receiver to recognize DSD with the TV on. HDMI will use the highest quality signal that all connected devices support. Since the TV does not support DSD, PCM was used.
post #2448 of 3485
Because I don't trust "Auto" setting to sort it correctly. At the very least, I'll be assured of a direct connection between disk and display with "Original Resolution" and display set to "1080P Pure Direct".
post #2449 of 3485
Thanks for getting back so fast! I will be working on these issues this weekend and I have some options thanks to you.
As far as the "Serviio" homestream, all I see is "Unknown Device" with a yellow dot. Apparently it is not recognizing the S790.
As I stated, I am new to home streaming and I am not sure that Serviio has a lot of setup options. Kind of reminds me of handshake issues with HDMI.
post #2450 of 3485
The more I use this player the more I realize how good it really is. I'm listening to Dire Straits "Brothers in Arm's" SACD right now and the audio quality is excellent!
post #2451 of 3485
I went home and did a reset on my router.
Patience paid off in that I now see the Sony Blu Ray player under device name and profile with a friendly green light! (Homestream/Serviio)
However, when I fire up the sony, there is no sign of the PC in the sony menu. It seems that the player is not cooperating.
The menu does show the USB stick that I have in the rear of the unit but nothing as far as the PC goes.
post #2452 of 3485
Force the player to find the server. Goto network settings and under connected DLNA servers hit options to find DLNA servers.
You can also hide/delete unwanted ones from this menu item.
post #2453 of 3485
I tried a logitech wireless keyboard and it didn't work, the player puts up the message "Unsupported USB Device". Oh well
post #2454 of 3485
Hmmm.... can't find anything under servers.
Nothing is popping up on the menu to connect to. Strange
post #2455 of 3485
Hi InfernoST, I'm using the Logitech wireless keyboard MK320 plugged into the front USB port (has the message "USB Device Front Unknown"). And it works on Amazon, Netflix, YouTube, Facebook, Video & Music Unlimited. The only app it wouldn"t work on is Vudu.
post #2456 of 3485
... K400 (K400r) also works. Touchpad works in browser only.
post #2457 of 3485
hi, i'm new to a lot of this tech. talk but i just started using a 790 and was wondering if i should have all the processing options off. i have a sony 950 tv and the guys in that thread turn off almost every option except for the local dimming. should i do the same with the 790 player. thanks for any info. also does anyone know if streaming netflix,youtube, insert site here etc. on the 790 will be any differnt than using my sony 950.
post #2458 of 3485
Thank you for testing. And what's the model number for this keyboard??? That way I can avoid buying it.
post #2459 of 3485
That's great. I will try it on my unit.
post #2460 of 3485
do you guys use auto for all your settings on the 790?
