Originally Posted by
imws
I start off within the sony site on my laptop it prompts me to login which I do and then there's an option to register a device, I next enter the 5 digit code on the Sony site and it adds the bluray player. I see on the bluray player that the device is now registered.
Now I see a bunch of services on my laptop that allows me to link to various services I click on the one for Amazon and it pops open a new page with a field for a registration code. I have to enter something here otherwise I can't go any further.
I think I should attempt to register from the player itself instead of using the laptop.
Sorry, one step I forgot. Ok, go back to the Sony essentials site and click on link to services. Amazon.com launches and begin registration. It will ask for a 5 digit code, but thats not the same code as what you used for Sony essentials.
Goto the player and launch amazon. Goto options and select account. Select link to account, and it will generate a new 5 digit code. Thats the code you enter into amazon.com
Go back to sony essentials and the status will change to green.
You're now linked.
Now Essentials and amazon are linked, you can add as many devices as you want to your sony essentials account, and amazon will be available automatically, you dont have to go through that step each time you get a new BD. I had already set this up for my Sony Bravia TV back in 2009, so my memory was a bit rusty. Good luck !
