specuvestor: pardon my ignorance
but please explain : " CLED " ??
they might also only buy the leds from another company ?
whatever it is ...they used something to create that prototype
and the resolution looks as announced from the pictures we've seen
so the size of the pixels must be in the range we calculated
as of now , i've browsed through almost all large known led manufacturer websites without finding any array or package small enough to work on that
particular display
so either it is a product unavailable on manuf websites
( which is doubt would be logical if it is a current product ..they want to sell it no ? )
or
sony has done some led investments in its factory nobody seems aware of
or
sony has ordered a custom product form a manufacturer
that is not available to other's than sony
i still think that if sony developped a led array specific for display applications,
they are going to put a patent on it as they always do
also m if you look at large pictures from CES , when the screen shows black parts, we can't see any details on the leds and spacing
so they must have worked alot on the spacing, color of the holding substrate
and color of the led substrate so that when it is off, we do not see reflected
light on the lenses or on the mirror under the dies, colors from the dies etc ...
maybe they installed 6 million tiny 2 legged leds in holes, connected them all by hand, and sprayed everything with mat black paint from the front
that would certainly explain the dark black
