I've found some interesting info late last night. Specs:
So that 3.5x contrast number we were wondering about ... that's actually in reference to a daytime/light environment. In a dark environment, it exceeds the measurable limit. Since it also has a brightness of 400 cd/m2 (similar to current OLED) ... this technology appears to basically have the same performance as OLED. Similar brightness, black level, and contrast.
Also, the power consumption seems pretty decent. I don't know what the upcoming OLED panels are using, but 70W is obviously a nice improvement over LCD. I'm curious what the 'ideal for large screens' is referring to. Do they mean at 55" versus other techs ... or are they insinuating this tech may be applicable for really large screens like 75"+?
One last thing before I update tonight (assuming I didn't lose my links - something bad appears to have happened with my google doc containing the info) ... a very interesting quote came out of this during an interview.
Where the reports of Sony bowing out of consumer TV OLED possibly wrong?
While ambiguous, some analysts are reading that this may imply continued OLED research for consumer displays. It's possible the prior information got lost in translation, and was referring to either the specific line, or the line and the specific type of OLED panel being employed? Hard to tell - hopefully this will get straitened out.
Regardless, this tech is starting to sound like a viable OLED competitor now that we have a better understanding of the specs. It may come down to fabrications costs and yields.
Tokyo, Japan - January 10, 2012 - Sony Corporation ("Sony") today announced that it has developed the next-generation self-emitting display, "Crystal LED Display," and presents a Full HD, 55-inch prototype model at the '2012 International CES' (International Consumer Electronics Show held in Las Vegas, Nevada, from January 10 - 13, 2012). It is the industry's first 55-inch Full HD self-emitting display using LEDs as the light source.
The "Crystal LED Display" is a self-emitting display that uses Sony's unique methods to mount ultrafine LEDs in each of the Red-Green-Blue (RGB) colors, equivalent to the number of pixels (approximately six-million LEDs for Full HD). The RGB LED light source is mounted directly on the front of the display, dramatically improving the light use efficiency. This results in images with strikingly higher contrast (in both light and dark environments), wider color gamut, superb video image response time, and wider viewing angles when compared to existing LCD and plasma displays, with low power consumption. Furthermore, due to the display's structure, the "Crystal LED Display" is also ideal for large screens.
Compared to existing LCD displays, the 55-inch prototype exhibited at CES is boasting approximately 3.5 times higher contrast in light environment, approximately 1.4 times wider color gamut, and approximately 10 times faster video image response time (all values based on current Sony models). Sony envisages a wide range of applications for its "Crystal LED Display", ranging from professional to consumer use. Parallel to its continued development and commercialization of organic light emitting diode (OLED) displays, Sony will work conscientiously to bring the "Crystal LED Display" to market.
< Main specifications of the prototype >
Panel size: 55-inch
Number of pixels: 1,920 x 1,080 x RGB
(Full HD: uses approx. 2 million each of RGB LEDs,
a total of around 6 million LEDs)
Display elements: RGB LEDs
Brightness: Approximately 400 cd/m2
Viewing angle: Approximately 180 degrees
Contrast (dark environment): More than measurable limit values
Color gamut: More than 100% compared to NTSC (xy)
Power consumption (panel module): Under approximately 70W
Panel size: 55-inch
Parallel to its continued development and commercialization of organic light emitting diode (OLED) displays, Sony will work conscientiously to bring the Crystal LED Display to market.
You do not want your current top of the line look like that!
The Crystal LED is brownish.
