AVS › AVS Forum › 3D Central › 3D Displays › Will the Sharp Aquous LC-60LE633U do 3D?
post #1 of 6
post #2 of 6
Did you investigate the Sharp site for the specs? No, it doesn't.
S~
post #3 of 6
I did. It has the required refresh rate and HDMI inputs. I know the TV does not have a 3D mode/setting. I was hoping that the Monoprice 3D converter (or similar) might work. But guess not.
Thanks for the response.
post #4 of 6
That's a different question. Yes there are devices for 120Hz TVs that will simulate 3D. Look in the components forum.
S~
post #5 of 6
Are you planning to buy this TV or do you already have it? If you're planning on buying a TV - DEFINITELY buy a TV with 3D. DO NOT, I repeat, DO NOT buy a TV and then buy some crappy converter.
post #6 of 6
Already got it. We wanted a new TV. the wife picked it up at Costco (on sale) and to surprise me, had it hung when i was out of town. We've had it for to long now to return in.
Is there a better converter then another or do they all pretty much suck?
  Back to Forum: 3D Displays
