i had time yesterday to compare both the jvc and the new sony with my
panasonic 65" 3d plasma tv.
based on my measurments i did about horizontal resolution and
vertica resolution and 45° long time ago i have found this numbers.
i copy the older measurments inside if you like to read more about it here is the link to my old post where you can see how it was measured in details.
the sony is the 10 model.
http://www.avsforum.com/avs-vb/showt...2#post21327232
horizontal resolution:
jvc 780 lines
sony 590 lines
"new sony20 660 lines"
z10k 590 lines
sony ex1r 2d cam 960 lines
vertical resolution:
jvc 790 lines
sony 620 lines
"new sony20 740 lines"
z10k 790 lines
sony ex1r 2d cam 840 lines
resolution lines 45°
jvc 830 lines
sony 690 lines
"new sony20 800 lines"
z 10k 690 lines
sony ex1r 2d cam 930 lines
as you can see the new sony 20 have more lines visible
compare to the old 10 model.
also it show all this with not the huge enhancement the jvc did.
in high freq. the jvc have all this bugs inside that are comes from strong enhancement like ringing stair steps and so on......
the sony have a very good very naturally picture till the end what the cam can record with not any! enhancement.
in low light the sony outperform the jvc by far.
all in all a big step up in picture quality so i may start to record in 3d again.
the new sony 20 is nice small and can record a better picture than the older
10 model.
the only disatvantage is the smaller distance between both optics as this
may have some negative impact.
to my surprise i cant see much when i compare it with the jvc that have a much bigger distance so for me not a big issue.
its also nice that you now can record very close things in 3d where the 3d effect is very good.
