Originally Posted by erickotz
Except other tuners may require services, libraries, COM objects, and other things that have been stripped out of the embedded install - there's just too many unknowns to officially support this. I'm not saying we are going to intentionally block it, but I can't see this ever being a supported feature.
As far as I remember, it has digital audio out - where did you see that it does not?
Let me ask this - what do you guys want as far as "backdoors" - I can't make any promises, but if you tell me what you're looking for, I'll see what I can do.
All I saw was a mini jack for audio, didn't see an optical port. If it's coax digital out from there, that's fine.
The backdoor I'm thinking of could be a simple 'advanced mode' setting (either hidden or not), which would enable tuners and WMC plugins to be installed. This would definitely be unsupported by Ceton.
An IR extender "eye". It has an eye on one end and a stick on emitter on the other end. Just stick the emitter on to the Echo's IR front (on top of the glass works just dandy), and extend theeye whereever you want. It can go up to almost 300ft.
