AVS › AVS Forum › Video Components › Home Theater Computers › Official Ceton Echo Extender Info Thread
Official Ceton Echo Extender Info Thread - Page 52
post #1531 of 7721
Very concerned about the lack of VC-1 and DTS support. This would render the device useless for me and a lot of others.
post #1532 of 7721
Originally Posted by crbaldwin View Post
Well, there's no mention of DTS at all, so that is not a good sign...
Crap-I missed that. I can live without HD Audio, but DTS is a dealbreaker.
post #1533 of 7721
Isn't vc-1 covered by WMV9 support?
post #1534 of 7721
Maybe maybe not. I think it needs to implement WMV9 Advanced Profile to handle the VC1 on Blu-ray or HD DVD.
post #1535 of 7721
Oh yes good point.
post #1536 of 7721
Why? im going to buy 2 of theses. i dont care if it cant play blu-ray rips or mkv. i just need it to play tv shows. it should dd 5.1
Originally Posted by stanger89 View Post
Woops, I totally missed that. I basically scrolled to look for format support and then was too disappointed to keep reading.
About the only hope I have at this point is that what's listed is what the Echo can decode, but that it can pass/bitstream other formats, but at this point I'm guessing not, and it appears my WMC experiment has come to an end.
post #1537 of 7721
I for one would be a lot happier if the thing could be made to run XBMC than if they tried to cobble MKV and other support into WMC. That's the way I use my PC now; WMC for TV only, and XBMC for all other video.
post #1538 of 7721
so why not just buy a dma 2100. it is the same thing, are much cheaper and available now.
post #1539 of 7721
+1
While it would be great if this little box could do everything, I've got plenty of other devices that can stream blu-ray rips and the like. As an extender, the Echo is ideal. I'm very happy with the way it turned out (small, quiet, low power, simple). I'll definitely be replacing my Xboxes when the prices drop a little.
post #1540 of 7721
Available on eBay now as used models, none newer than what, 3 years old? My experience with the DMA2100 about a year ago was not good, and I found prior discussions about the problems I had. It stuttered occasionally when configured to output 1080p (definitely not 29/59 related), it had occasional reproducible audio glitches when configured for 5.1 output that did not occur when using the HTPC directly, and it needed to be rebooted every couple of weeks. The first two problems could be worked around by using 720p and stereo, and that's the only way I would recommend using the thing.
post #1541 of 7721
I was hoping for MKV and DTS support. I mean this is almost a xbox that uses less power and space?
post #1542 of 7721
Because I've already got SageTV and 3 extenders, and SageTV is a way better DVR than WMC (yes Sage lacks the DRM to play protected CableCard recordings). WMC is (was?) my fallback plan when SageTV or my extenders die. I need something that's functionally equivalent to what I have with SageTV and my extenders, and the info given the Echo falls far, far short of the HD300.
post #1543 of 7721
I'm in the same boat as you Stanger. Still holding on to my 3 HD300's until something better comes along. I was hopeing that would be the Echo... Perhaps the Tivo Mini will deliver
post #1544 of 7721
The great and mighty Motz has spoken:
Originally Posted by Motz
I obviously can't talk more about anything but what is on the site, but as for codecs/containers, all of my movies already are in .m2ts container(AC3 audio with H264). I did this a long time ago so they just work with media center and extenders without having to install anything (http://thedigitalmediazone.com/2010/10/25/making-mkv-files-play-nice-in-wmc-with-mkv2vob/). My files are streaming just fine smile.gif
http://thegreenbutton.tv/forums/viewtopic.php?f=69&t=3088&sid=e4e9ae094db84eba7a847acb9895f94f
post #1545 of 7721
This isn't very helpful. There are a number of reasons not to convert movies to other formats, mainly ease of use and preservation of quality. Supporting all blu-ray codecs is crucial for people that want to playback their high quality blu-ray movies on the Echo. I wasn't really expecting lossless blu-ray audio support, but we at least need VC-1 and DTS. Can you even convert the blu-ray audio losslessly to a format the Echo supports? I don't see FLAC support.
post #1546 of 7721
You could convert it to PCM, but I have my doubts it supports 7.1 PCM given the other specifications.
Eric/Motz, if you can't talk about what's not on your site, you better update your site with what the Echo can actually do if you don't want to lose a "lot" of your beta testers.
post #1547 of 7721
+100
post #1548 of 7721
And don't forget that the 360 can do a lot more in the terms of streaming services also. (Netflix etc)
post #1549 of 7721
IMO, why should we have to convert anything in this day and age? We should at least be able to play a ripped dvd with DTS, I should think, or why bother releaseing a product at all.
That being said none off us have an Echo in our hands yet. Maybe Ceton will provide us with great FW updates and this will be a moot point. Or we will just have a DMA 2100, which I tested for two days and returned promptly.
post #1550 of 7721
It supports PCM but how to get, say, dts-HD/MA converted to PCM on the fly?
Also, How to convert mkv back to m2ts on the fly?
I mostly want a PVR/DVR extender but the cost of this is a bit high if these issues aren't worked out durnig the beta program.
I wonder if third party f/w flashing will be permitted but ceton would need to release the source code.
post #1551 of 7721
Kind of on topic, has anyone been able to login to the Ceton forums yet? I registered but have not received a confirmation email. When I registered it stated I could not post until confirmed. But I can't even see the forum topics at this point?
post #1552 of 7721
So many questions..
1. Can I connect a bluetooth usb adapter and use bluetooth enabled devices like a smartphone or a Logitech diNovo mini?
2. Can I use wireless Ethernet adapter via usb?
3. Can I use my harmony remote with it (i.e.. program a Ceton echo device into the harmony)?
4. My infinitv PCIe card is connected to my WHS2011 server and the tuners are distributed to other HTPC's via network bridge. Would those tuners be available to the echo?
5. Will it play back any movie I can throw at it (mkv, avi, mp4, etc...)
post #1553 of 7721
Make room in your boat for me! I am in the same situation.
I was hopeful the Echo would have as a minimum the same feature set as the HD-300. Whats even worse is the Echo has less features and will only work on a dieing product (WMC).
post #1554 of 7721
I couldn't even find the beta forum. I didn't see a link in the email I got.
post #1555 of 7721
I have a Patriot Box Office that streams HD Audio. The GUI is a flashed Med8tor f/w and runs a little slow but the PBO plays mkv's with full HD Audio in 1080p24. It cost me $60 a year and a half ago. The Echo needs to support these formats to be a success IMHO.
post #1556 of 7721
I don't have a problem with video codec support. I really don't need anything besides mpeg2, h.264, and vc-1. But, I am troubled by the lack of DTS support. I probably should have seen that one coming. Its a huge problem for playing back blu-ray rips on secondary TVs without receivers. That alone is going to cause me to give this a second thought.
But really, I'm more troubled by Ceton's unwillingness to give us straight answers on media playback capabilities. We've been asking about container support for a long, long time. I really don't get why they aren't saying anything there.
If you're playing bluray rips with DTS, I'd imagine this does the same thing as the Xbox does with DTS and downsamples to 2ch (I think?). If you're not using a receiver, then that should be sufficient, no?
post #1557 of 7721
That should be fine for connecting to a TV but eventually I want a system in the spare room too.
post #1558 of 7721
All of those jumping ship - put in a good word for me and I'll gladly take your spot!! biggrin.gif
post #1559 of 7721
You can't have mine. I'm in. Should be just fine for my purposes anyhow.
post #1560 of 7721
This should help:
It was at the bottom of the email - "How do I Give Feedback"
http://www.cetoncorp.com/forums
This thread is locked
