Originally Posted by dsurkin
Here on Cablevision/Optimum, the Cisco TAs are well-known for random reboots, which foul up recordings on Tivos and Moxis (RIP). Cisco, to my mind, has no interest in solving this issue or providing any support. Do you have any insight into how this problem can be resolved? One solution I've heard is to just not connect the TA, and forgo those channels that are switched digital. I would sooner do that than subject my soon-to-be-acquired Q/Echo system to random reboots.
And yeah, I'm buying one Q and one Echo the day you put them on sale.
So, by no means am I saying TAs are perfect, but they have gotten a lot better in the last year. I will say we have (and are continuing) to put a lot of effort into making the TA experience more reliable, and I'm actually scheduled to go into TWC's lab next week to do some more testing with them.
I can't say I've seen TA's spontaneously reboot since the 1501 TA firmware from Cisco. There is a known issue on the 1402 firmware, but 1501 fixes it and we've worked with most MSOs to get 1501 deployed ASAP.
I will say that Cisco's TA group (which is different than their CableCARD group and their SDV server group) has actually worked with us and provided some feedback, and we have worked with them (the only reason the current Cisco TA firmware supports 6 tuners and not 4 is because we sent them a 6-tuner InfiniTV) so perhaps we actually have more reliable TA support that our competitors?
If you can simply ignore the TA or not depends on your system. In my case, there are literally about 6 non-switched HD channels so I essentially have to use a TA or my setup is useless.
Are you experiencing specific TA-related issues?
I'm going to defer to the nearest Magic 8 ball for the answer on that one
