Originally Posted by FantaXP7
I guess I am missing the point a bit here. What exactly is the main purpose of the 7MC VM then? For central recording storage and a library that the extenders look at?
Also your HD Homerun Prime....will that possibly be compatible with the Echo? I haven't been following this thread much at all. But I assumed it wouldn't.
I need to take a close look at what the Echo will be able to do, but I for sure hope that, like you, it will handles BD rips.
Yes, the purpose of the VM is to make 7MC a server and have a central repository for recordings. That way you can have an extender only setup. The server ,as it were, is nothing more then a recording/licenseing box which has no real value for viewing other then authenication for the extenders.
As for working with the Echo, the HDHR Prime is not seen by the extender and is only in the tunner pool for WMC. So any tunner/capture device support by WMC will work with the Echo. Now if we could say that with filetypes we would have something, wouldn't we?
