Not exactly correct. You can still use PlayReady as long as you can afford to pay the licensing costs. Basically, protected cablecard content must be recorded using one of the CableLabs approved DRM schemes. IIRC, there are only three that are approved:Originally Posted by Foxbat121
Then they need start working on their Q with their onw stuff first. Echo is just a terminal, not the main content server. It is possible, with a company like TiVo. Not sure if Ceton has the financial means to get into TiVo business. Remember, you can't use any MS stuff now if you are going to do it yourself.
- PlayReady (Microsoft DRM used by Media Center)
- DTC-IP
- Helix DRM
They could still license PlayReady and use it in their own system. I proposed something similar not too long ago:
Create a "black-box" application that will play PlayReady protected content that could be controlled by any application. The black-box app would take care of the protected playback path but would expose methods for Play, Pause, Record, etc that could be called by any application (the goal in mind was F/OSS apps like NextPVR and MediaPortal). It could also be extended to stream the protected content across a network that could be decoded by "extenders". Eric (of Ceton) said that he might be willing to pitch the idea for Ceton to financially back a project like that for F/OSS but they could easily sell the application for commercial apps (like JRiver) to be able to incorporate it as well.
If I ever get the time, I plan of creating a proof of concept for the black box app but right now my time is very limited for F/OSS programming. Gotta make sure the bills are paid first.
Edit:
I should have read the rest of the thread. Ben beat me to it.
Edited by vladd - 12/1/12 at 7:35am
