Originally Posted by
EAS
I fixed that for you.
Actually you didn't fix it for me - I meant exactly what I wrote. Ceton has announced that Android support will be added, so that means that the Echo should be more than just an extender before too long. At that point it comes down to a choice between extender + gaming + some apps (as long as you pay for XBOX Live) or extender + android support (whatever that ends up actually meaning, of course) + small + silent + runs cool.
EAS
At least color code it copycat.
Agreed - if you edit a quote at least make it clear where the edit was. It's not at all cool to change someone's words, but still attribute the modified post to their name without making it very clear what was changed.
Sammy2
The beta program was too short but I think these issues will be hammered out soon.
IMHO, the public beta started too soon relative to where they were in their development cycle. As others have mentioned before, a public beta should actually be very close to production ready and have most, if not all, major functionality working. The point should be to identify issues that can only be found with a larger sample set of interactions between hardware to work with. Basic stuff like 1080p output and bitstreaming Dolby Digital should have been working.
mariob33
both devices require line of sight for the remote to work. so hiding either is a 50/50 proposition
There are several ways to deal with line of sight, some of which have already been mentioned. They include using an IR repeater system, the Ceton Companion app, a Windows Media Center USB IR receiver plugged into the Echo's USB port, and any other smart phone app out there that can control an XBOX. Ceton has also said that they'll be providing HDMI CEC control at some point - assuming that happens, you would be able to use the TV's remote to control the Echo.
Sammy2
That is a good point. Can multiple smart phones have the companion running on them to control the same device?
Yes - I have the Ceton Companion App installed on both my iPad and iPhone.
