Yes, I do on my Sony BD player. DTS-HD MA 7.1 without problem.
Originally Posted by bdraw
Ok, pretend you are a brilliant Windows Media Developer with a vast knowledge and understanding of codecs and containers and have intimate knowledge of the Echo. Would you use the Divx spliter and sharky codec pack to satisfy your (and your customer's) desire to play various media files on on your Echo? Or perhaps something different?
No, I'm not and found this codec/splitter mess nothing but headache. Hence I go with whatever works in the simplest form. Currently Echo is not my primary streamer because it won't do HD audios. My BD player from Sony is. So, I would go whatever gives me the result I want. That means streaming within WMC is not my priority. Outside of WMC is.
Everything non-PC just so much easier to setup and use in HT.
