AVS › AVS Forum › Video Components › Home Theater Computers › Official Ceton Echo Extender Info Thread
Official Ceton Echo Extender Info Thread - Page 151
post #4501 of 7721
Originally Posted by tjgertge View Post
I've been having a very rare random issue, I'm hoping someone can point me in the right direction. Once in a while a little popup will come up in the upper right corner that says network issue. When that happens the audio/video gets really choppy. I tend to notice this happening more when watching HD football or basketball It will happen for about 5 seconds and then clear up.
I have a HTPC server that has the following specs:
ASUS P8Z77-M Pro mothboard
Intel I5-3570K with Intel HD4000 graphics
2 3TB Western Digital Red hard drives - Raid 1
16 GB of Crucial Ram
The NIC chipset is Realtek, and I am using the onboard LAN
2 InfiniTV 4 Pci-e cards.
My core network switch for the house is a 24 port TP-Link gigabit unmanaged switch.
The server connects directly to that switch.
From the switch, it connects to a small 5 port D-Link switch so that some other AV equipment can connect to the network. This is where my Echo is connected.
I've tried eliminating the small switch, and that hasn't helped.
Has anyone else run into this trouble? I have heard some say they don't like Realtek based NICs. Which if that is the case, I can go get an inexpensive Intel based NIC. Are there any settings that I can look at adjusting on the server side to help?
I will say that the problem got significantly better after the 2012.1213.1022 upgrade that fixed all the interlacing issues.
Networking issues can be tough to troubleshoot. I would replace the on-board nic with an Intel nic (make sure they have drivers for your os). Disable the on-board nic. Check it out and see if you still have issues. I have my HTPC and Extenders on a separate switch along with one connection to the router for Internet. The rest of the home is on a separate switch which also has one connection into the router for Internet.
post #4502 of 7721
I upgraded to the newest beta firmware - 2012.1213.1022 - but my Echo still locks up / becomes unresponsive constantly. I use the remote to turn it off, then back on and it works until the next time. Sometimes the video gets stuck and the audio kind of stutters until I turn it off, sometimes it is just unresponsive.
If I turn off my TV but not the Echo and come back later I usually have no video and have to turn the Echo off then on, and sometimes I have a green tinged screen and again have to power cycle. Is everyone dealing with frequent lockups like this? They don't seem to be hard lockups since it still responds to the remote power button, but it won't respond to anything else.
post #4503 of 7721
I'm not experiencing any lockups or stuttering of video or audio. I wonder if you have a bad unit?
post #4504 of 7721
Mine only does that when I try to play an unsupported file type in an mkv such as H.262 or dts.
post #4505 of 7721
Try setting the Echo to 720.
post #4506 of 7721
Mine running latest beta firmware did rebooted couple times during live TV. Tell tale sign is audio went out first. Then Echo reboots.
post #4507 of 7721
Well, I was doing ok until 1022. Now the echo is slow to respond and I am getting video stutter. For a good 2 minutes after booting it was not responding to any commands.
Edited to add that like flerve the echo will respond to the power button when it is locked up. But it ignores all other key presses.
Edited by BeerCan - 12/18/12 at 7:41pm
post #4508 of 7721
So I see that new firmware 2012.1214.1414 is available in the beta channel today. Can anyone tell me what this fixes?
PS. I got my 4 additional echos installed today, so now I am running a total of 5. Works like a charm!
post #4509 of 7721
Here you go. I included last few in case.
2012.1214.1414
New splash graphics
Improvements to startup and shutdown.
Stability improvements
**if you are experiencing any hdmi issues and had your output set to native, please adjust to 720p or 1080p first and then you can adjust back**
2012.1213.1022 (Beta)
Includes previous, plus minor install tweaks.
2012.1212.1449 (OMEGA)
Improve playback quality of interlaced content
Stability fixes
Add 'Native' resolution setting to playback content at its original resolution
Make device webpage more functional
Detect missed HDMI unplugs
post #4510 of 7721
Hi guys, I am running Windows 8, so I have my Echo working through the Companion app for now. Since I can't access the settings on the Echo, is there any other way to set it to the beta channel? Thanks!
post #4511 of 7721
Type the IP address of the Echo into a browser and click on "settings".
post #4512 of 7721
Well, my RMAed Echo came back yesterday. I'm running it now, on Beta 2012.1214.1414.
One thing I notice, when set to 1080p, frame rate is not smooth, watching sports, you can see it jump, and Ticker scrolls are jumpy too.
Setting it to 720p, it's smooth. Anyone else seeing this?
post #4513 of 7721
This is assuming he's running at least 2012.1212.1449 correct? I don't think I got the option to change settings in the webpage under 1022.
post #4514 of 7721
I watched the Lakers last night on TWCSportsnet which is 1080I. My echo is set to "Native" and the playback was very smooth. Plus I had no random re-boots, green screens, green bars or any other problems.
Now for HBR mkv playback with ALL audio streams. How's that coming along, ceton?
post #4515 of 7721
Well, I tried "Native", but still had jumpiness in scrolling tickers. The TV also showed 720p60 on any channel I tuned. The TV is native 1920x1080.
Went back to 720p setting on the Echo, and it's back to smooooth.
Beta 2012.1214.1414
To recap:
Set to 1080p in Echo settings, jumpy picture and jumpy scrolling tickers (worst)
Set to Native in Echo settings, fairly smooth picture, still see some jumping on tickers (better)
Set to 720p in Echo settings, smooth picture and tickers (best)
post #4516 of 7721
My issue with latest beta 2012.1214.1414 (and past few) is that if I force 1080p, any 720p channel (like ESPN HD) stutters and is laggy. Everything else looks great. If I use native, everything looks great. If I force 720p, everything look great. Perhaps I didn't run at native long enough to notice the jumpiness you mentioned, but at 1080p it was unwatchable- worse than before the beta firmware initially fixed things...
post #4517 of 7721
Native looks good for me on all channels I have tested.
post #4518 of 7721
I have this same thing going on. I would like to set to 1080p, because I have a 1080p tv and when i set the echo to Native, then all the menus in media center are in 720p. However, video on 720p channels is choppy and stuttery just like you mention when set to 1080p. Video works fine in native, but those giant oversized 720p menus are a drag. Actually, it would be great if they added a "native" setting that will allow the media center interface to be displayed at 1080p, but play back video at native resolutions.
Edited by Munkee Boy - 12/19/12 at 10:44am
post #4519 of 7721
Good point. I don't remember which firmware enabled that.
post #4520 of 7721
Hopefully we'll get 1080i native passthru soon. BTW - 2012.1219.1030 just got released.
post #4521 of 7721
I was on 2012.1202 but now I have the new 2012.1213.1022 update so now I can reach the settings via the web.
post #4522 of 7721
In http, can you click on Beta? Then use the remote to re-boot the Echo? Refresh http and click updates? Had to re-boot mine a couple times for beta to stick.
post #4523 of 7721
Interesting. So when you watch a ticker on say CNBC, Bloomberg or some other news channel, it never repeats or drops a frame at all? Even if you watch it for several minutes text always scrolls at constant speed? That would mean they somehow worked around the lack of 59.940Hz support on their HDMI transmitter. Can anyone else confirm this? Would probably be easier with the 59.940 test patterns I posted in this thread a few weeks ago but I'm not sure how those play over media center extenders.
post #4524 of 7721
I am running the 2012.1219.1030 version of the firmware. The Echo has matured a lot in the past couple weeks. I have been using ESPN2 as my test channel for the scrolling issue. The scrolling issue is gone as far as I can see. Combing on channel 2,3,4 has been corrected as well. The whole experience is completely different from a couple weeks ago.
post #4525 of 7721
My observations did not extend to those lengths. It's quite possible there is a jump after 'several minutes'.
post #4526 of 7721
the test scrolling test (I have your posted ones) is still there its just seems to be much more bearable. They have done an incredible job of smoothing things out.
post #4527 of 7721
I just installed f/w 2012.1219.1030 and I am having audio issues now. I haven't had audio issues since early in the beta. The PQ is fantastic now and was under the previous f/w. This latest beta brought on audio issues that even a re-boot won't fix.
post #4528 of 7721
Can you describe the issues? I updated last night too and it looks and sounds ok.
post #4529 of 7721
I also noticed some audio issues. But I think it is related to the TV and the soundbar.
The issues I experienced only occurred when running in "native" mode. As I changed channels, the resolution would of course change as well, and 50% of the time, the audio would not get picked up and played. If i change the channel again and change it back, the audio would usually come back. Because of this, I am still running in 1080p mode, and haven't seen the issue. My first guess is that it is somehow related to the HDMI handshake that happens when the resolution changes, as I have HDMI going from the Ceton to a Toshiba soundbar, then from the soundbar to the television. But I am no expert.
Also, I do have occasional loud static pops and squeals when the audio stream first starts. Much work if I have bitstreaming turned on, but it is still there occasionally with stereo output. As i said, only as the audio stream first starts up for a channel.
post #4530 of 7721
I didn't try changing the video resolution but did change the audio to PCM with no change in audio output. I hadn't had this problem on the 2012.1214.1022 f/w or since very early beta f/w but even hen a reboot brout the audio back.. but not this time.
I sent diag logs to ceton and logged it in the beta forum and tracker.. Hopefully they get it worked out as this f/w has been a regression for me even though I haven't seen the green monster or stripe (yet).
This thread is locked
