AVS › AVS Forum › Video Components › Home Theater Computers › Official Ceton Echo Extender Info Thread
Official Ceton Echo Extender Info Thread - Page 154
post #4591 of 7721
Originally Posted by jchusky77 View Post
I was reading though..I can shut off my DHCP client and assign each computer I have. but I dont know how to assign the ECHO itself.
I don't think you have to (or even "if" you can) assign a static IP to the Echo itself. I think Echo asks the router what IP's are available. You get whatever the router dishes out.
Maybe your router has a setting similarly named as mine, that I have enabled. My setting is called "Manually Assigned IP around the DHCP List". When this is enabled, Echo has the same IP reserved for whenever it wants to use it.
What is the model number, and firmware version, of your router? Maybe someone here has the same one, and could suggest further.
Edited by crash2009 - 12/23/12 at 12:33pm
post #4592 of 7721
Originally Posted by Sammy2 View Post
I still cannot download the 1221 f/w. Anyone else able to grab this f/w?
I am having the same problem - cannot get this firmware.
Football is unwatchable for me at this time. Too much "jerk" in the picture.
Ray
post #4593 of 7721
Stop watching __________ (fill in the blank with your most hated rival team)
Firmware level? Set to Native, 720p, 1080p, ? Which channel; are they broadcasting 1080i or 720p?
post #4594 of 7721
I've been watching FOX football. I expected a stutter on pans across the field, but it hasn't been apparent. There is a lot of breaking up, but that appears on my cable box also.
post #4595 of 7721
That's what I mean, the Echo doesn't provide an option to assign a static IP so you have to use a static assignment.
post #4596 of 7721
Well, IDK, but my echo has audio again. These last two f/w's have been odd in their implementation, to say the least.
post #4597 of 7721
Is there anyway for the echo to run a plug in that WMC is running? I want to add Caller ID on TV which my HTPC can passthrough to Media Center. I'm wondering if there is a way to make this work on an Echo. I'm in the preliminary stages of designing my HTPC build and would like to use Echo's for my additional outlets.
post #4598 of 7721
Only plug ins that are specifically programmed for extenders, MediaBrowser being one of them.
post #4599 of 7721
Google Windows 7 CallerID; claims to work with MC extenders.
post #4600 of 7721
http://w7callerid.com/configuration-samples.aspx
post #4601 of 7721
It actually works the other way around.
post #4602 of 7721
Yes. It should just work.
post #4603 of 7721
So all plugins will work on extenders that are programmed to utilize them? Interesting.
post #4604 of 7721
I specifically asked this of Ceton and was told the plugin had to be specifically programmed to work on the WMX platform. If I recall, I was having trouble with TMT5 and HULUplus crashing the extender.
post #4605 of 7721
My Linksys offer DHCP reservations, that is how I have mine setup....
post #4606 of 7721
1219 f/w and only bad on 720p programming. 1080i looks good.
I have to run in 1080p mode. I cannot run in Native as the Echo and my Pioneer Elite Plasma will not sync correctly at 720p. I get a 4x3 picture. Try to unplug and replug the Echo, and get a "green screen".
Fox here in Minneapolis is 720p and the football games yesterday were unwatchable. NBC is 1080i, and Sunday Night Football looked just great!
So - only the 720p sources have an issue.
post #4607 of 7721
They might have misunderstood the question. Neither of those "addins" should show on a MCX, they perform PC specific activities.
In general an addin doesn't need to do anything special to work in an MCX (RDP) session. It's only when it does something particular to having a PC execution context underneath and doesn't account for it that we have a problem.
post #4608 of 7721
that's makes sense.
post #4609 of 7721
Originally Posted by ZenithPete View Post
Anyone seeing choppy video or a sort of strobe like echoing effect on BBC America HD or HGTV HD, possibly other channels, but most seem ok. This is constant on every program on these channels. Both of these are 1080i channels but most other 1080i channels I don't see any issues that are too noticeable.
I am using a PC to serve the echo that has a ceton card and a FIOS cablecard.
I do not notice the same thing from my FIos DVR or watching from media center on the server computer. The TV set is a 1080p LCD with hdmi.
I have tried native, 720p, 1080p in the ceton settings and it doesn't seem to make a difference. Same issue is present on the latest beta firmware and previously on the latest official firmware.
Same here. Running f/w 1219. I don't think that happened before on the 1213 f/w. Also using FIOS cablecard with an InfiniTV4. Also tried all resolutions. No improvement. I remember that I used to have a problem like that on an old Linux box. If memory serves right it had to do with a faulty pulldown sequence or some such....
post #4610 of 7721
Speaking of these "addins". I would like to know what "addins" are currently working properly with the Echo? I am using three that work with the Xbox 360. mcShoutCast, My Channel Logos and Media Browser. Anyone else using other "addins" that work with both the HTPC and MCX?
post #4611 of 7721
My Channel Logos and Media Browser both work. I don't use Shoutcast so I cannout report if it works. What is that, BTW?
post #4612 of 7721
Thousands of web radio stations. Take a look here mcShoutCast
Missing remote has an older review here Life With a Plugin Episode 23: mcShoutCast
post #4613 of 7721
I'm seeing the logos part of My Channel Logos but the program type grid colors aren't working on the echo. It works fine on the PC.
post #4614 of 7721
The grid colors have to be turned on under settings/tv/guide/guide page options on the echo.
post #4615 of 7721
Now that I'm thinking about this, are the guide colors even part of My Channel Logos?
post #4616 of 7721
No. They are part of WMC.
post #4617 of 7721
Okay. Audio has disappeared from my Echo again but the green monster has returned. The odd thing is that the music channels actually have audio as do the mkv's that will play?
post #4618 of 7721
The Echo knows that it's Christmas, and wants you to enjoy the holiday music, without TV distractions.
Edited by flipper59 - 12/25/12 at 10:43am
post #4619 of 7721
Do the channels have audio on the local PC?
post #4620 of 7721
DTB & RecordedTV HD
This thread is locked
