AVS › AVS Forum › Video Components › Home Theater Computers › Official Ceton Echo Extender Info Thread
Official Ceton Echo Extender Info Thread - Page 195
post #5821 of 7607
Originally Posted by skybolt View Post
Ok, bad choice of words. And yes MCE buddy can move files around, but can only be played fron the original recording device. The white paper for DTCP implies you can move DTCP files and play on another PC/Device, at least it looks that way, that is what I was trying to imply. Unless that implies only an extender?
I believe that requirement will be determined by CableLabs, not DTCP alone. Copy-once means copy only once, not many times. DTCP must honor that.
post #5822 of 7607
DTCP-IP is not a copy, it is a stream.
xnappo
post #5823 of 7607
^^^ Those are both good points, and why it is very confusing and subject to inturpitation until someone actually tries to impliment something like a new DVR solution supporting this functionality.
post #5824 of 7607
xnappo
In the context we are discussing above, it refers to the files persisted on the HDD and whether or not it can be moved or replicated to another device/PC. There is no real advantage of DTCP vs PlayReady other than who you have to pay license to and who get more industry wide support (DTCP).
Saying DTCP is just a stream is also misleading. It is an entire system from stream to storage and playback. Only when the entire content path is secured, will you be certified to use DTCP.
post #5825 of 7607
Hey - I agree there. That is the key. Microsoft has its own agenda, which is why it is good to have a broadly industry supported alternative.
xnappo
post #5826 of 7607
Originally Posted by Sammy2 View Post
There were issues with Skip >| and |< in the 129 f/w that were fixed in the 206 f/w. You are the first one reporting this. You might want to open a ticket with ceton.
Yeah that was my next stop, just wanted to make sure there weren't some other silent suffers out there smile.gif
Really odd, because I'm seeing this with plain WTV files that WMC recorded.
post #5827 of 7607
xnappo
Exactly, we need to get away from Microsoft.
post #5828 of 7607
DTCP-IP is not an entire system from stream to storage to playback. It is a transport only DRM scheme. For storage or playback, the DRM must be handed off to another DRM scheme. PlayReady is one of the DTCP-IP approved DRMs for both storage and playback: http://www.dtcp.com/approvedtechnologies.aspx
Approvals for Persistent Storage and Digital Output Reprotection Technology
DTLA has granted approval to the following technologies for the persistent protected storage of content that has been delivered using DTCP, pursuant to Appendix B, Part 1, Section 2.2.1 of the Adopter Agreement:
1.1 D-VHS, licensed by Victor Company of Japan (JVC)
1.2 Content Protection for Recordable Media (CPRM), licensed by 4C Entity, LLC
1.3 CPS for BD-RE, licensed by Matsushita Electric Industrial Co., Ltd., Koninklijke Philips Electronics, N.V. and Sony Corporation
1.4 Vidi Content Protection System ("VCPS" or "Vidi"), licensed by Koninklijke Philips Electronics, N.V.
1.5 MG-R (SVR) for Hi-MD, licensed by Sony Corporation
1.6 MG-R (SVR) for MemoryStick Pro, licensed by Sony Corporation
1.7 Windows Media DRM 10 and future versions, licensed by Microsoft Corporation (provisionally approved)
1.8 Security Architecture For Intelligent Attachment (SAFIA), licensed by Hitachi Ltd., Pioneer Corporation, Sanyo Electric Co. Ltd. and Sharp Corporation
1.9 Advanced Access Content System (AACS), licensed by Advanced Access Content System Licensing Administrator, LLC
1.10 Marlin Technology for Import, licensed by Marlin Trust Management Organization. (Note: Until further notice, DTCP content marked with the Analog Sunset Token or the Digital Only Token may not be passed to Marlin Technology for Import)
1.11 IPRM-HN, licensed by Motorola Mobility, Inc.
1.12 Nagra Media PRM, licensed by Nagravision, SA.
1.13 Sony MG-R(SVR) for EMPR, licensed by Sony Corporation.
DTLA has granted approval to the following technology as a protected digital output, pursuant to Appendix B, Part 1, Section 4.4.4 of the Adopter Agreement:
2.1 High-bandwidth Digital Content Protection (HDCP), licensed by the Digital Content Protection, LLC
2.2 Windows Media DRM 10 and future versions, licensed by Microsoft Corporation (provisionally approved)
2.3 Pro:Idiom, limited to use in closed hotel environments, licensed by Zenith Electronic Corporation
2.4 Verimatrix VCAS Content Protection System, limited to use in closed hotel environments, licensed by Verimatrix, Inc.
2.5 Samsung Conditional Access System (SCAS), limited to use in hospitality TV services, licensed by Samsung Corporation.
xnappo
DTCP-IP is NOT an alternative to PlayReady if you want to record.
post #5829 of 7607
Mkay so the big question is, would they even license a storage protection scheme running on an open source copy of Android or Linux? If not then you're right, we're stuck with Windows-based DVRs assuming someone wants to partner with SD for a Playready-based solution.
post #5830 of 7607
Closed source applications/technologies can be created for open source OSes like Android or Linux. Just because the OS is open source does not mean the application needs to be. Whoever created it would need to submit it to DTCP-IP or CableLabs for approval (not trivial in either case). Submitting it directly to CableLabs would bypass the need for DTCP-IP licensing. I don't know if any of the current DTCP-IP approved schemes are available on Android/Linux.
post #5831 of 7607
Yes, I'm sure this was discussed many pages back when I finally came to the realization that what Vladd points out about DTCP-IP and PlayReady are true by finding that information doing a google search.
This discussion persists.. We need another f/w update to hash about!
post #5832 of 7607
... This discussion persists.. We need another f/w update to hash about!
It just supports the fact that we need a real extender which supports all that was discussed prior to the private public beta. I mean it looks like a lot of Echo's are going to be returned, I know not your's but just saying.
post #5833 of 7607
It does WMC real well but for $180 (or $165) I'm rethinking about getting another one unless there's some real improvement for everything else soon!
post #5834 of 7607
Agreed. I want to make the leap but since I can buy Linksys DMA 2100/2200's all day on Ebay for under $80 it is hard to justify the purchase just for smaller/more energy efficient.
post #5835 of 7607
Based on my understanding of how all this works, Copy Once doesn't actually mean that you can only make one copy. It means you can only make one generation of copies. When you record a "Copy Once" channel, you have not yet made the first copy. In theory, you could make an unlimited number of copies using the original copy you recorded as the master. You would not be able to make addition copies of your copies (as they will have become Copy No More, or CCI 0x01)
DTCP actually has it's own group (I believe it's called DTLA) and you wouldn't have to have anything certified by CableLabs.
post #5836 of 7607
Hey Folks...I have a support ticket open with Ceton right now and they have been working with me off (mostly off) and on over the last several weeks on my issue and I wanted to run this by the experts here and see if any ideas spring to mind...here is a copy of my last response to them, I hope everyone can understand the issue...basically if I turn the Echo off, wait a moment then turn it back on it is crashing my infinitv card in the HTPC so that I have to not only turn off the Echo but I have to reboot the HTPC the infinitv card is in...then pairing with the Echo works fine and everything is wonderful...good picture quality, sound, etc...until the Echo is turned off and the cycle repeats itself....obviously could just leave the Echo and HTPC on all the time but of course that is not an optimal solution...
"Still same issues…when echo turned off and back on again it is still not pairing with HTPC and still crashing the Infinitv card so that HTPC has to be rebooted every time…in addition to this now when I reboot the HTPC and then turn the Echo on the pairing is fine except that last few days the echo will lose pairing randomly even if everything is running smoothly up to that point…no rhyme or reason to it it just loses pairing in the middle of watching a show…then of course that crashes the Infinitv card in the HTPC and cycle must be started over…"
Any suggestions would be most welcome...I think this is some kind of hardware issue...possibly my router (which is an outstanding Buffalo router I might add). The Ceton folks have already had me perform a recovery and then upgrade to latest beta so that is what is on the Echo right now...
post #5837 of 7607
DTCP, DTLA, PlayReady.. all a bunch of crap that makes a lot of people money from licensing fees without actually lowering piracy/copying. Sigh. Excessively confusing situation.
post #5838 of 7607
Yes, I'm sure this was discussed many pages back...
I think this is the third time now that I've discussed it.
Yup. I meant that there was a choice of
1. getting the DRM approved for DTCP-IP and using OCUR -> DTCP-IP -> approved DRM
or
2. getting the DRM approved through CableLabs and using OCUR -> approved DRM (skipping DTCP-IP).
If someone chose to do #1, they wouldn't need CableLabs approval because DTCP-IP is already approved by CableLabs.
post #5839 of 7607
Eric - State of the Echo, please.
Maybe us paying customers are annoying you by asking for this again and again, but I think we deserve this by now (if not a whole lot more). We paid for your released product only to be doing the beta testing for you. So, what's up?
post #5840 of 7607
At the very least, give us a hint about when you might be making a post about when Ceton might be making an announcement about when they might be releasing an update.
post #5841 of 7607
Ha!
post #5842 of 7607
xnappo
Sorry, this is a little OT, but since you're a JP1 guy, can you confirm what protocol ID, device and subdevice the echo uses? I'm trying to match it up with an existing setup code. And if you use a JP1 upgrade from hifi-remote, which one exactly is the best match? Lastly, if you've made any tweaks, would you please post your Echo upgrade over there?
post #5843 of 7607
Actually more on topic than discussions of DCTP-IP I think.
post #5844 of 7607
I submitted a support ticket last night to return the Echo, but I wasn't sure what to say in the request. Does anyone know what information they need to process the return?
I was holding out to see what was going to happen with Android, but we pretty much ran out of time with the current return deadline. Even if they pushed out an early beta version tomorrow, we're not going to have enough time to test it. I certainly expect the initial release will be buggy, and I also suspect some Android app developers will have to make some updates to their programs so that they will run acceptably on the Echo. We're certainly not going to have enough time to see how that goes before we hit the end of February.
'm also not thrilled with the communication from Ceton throughout this process, so I'm not inclined to give them te benefit of the doubt. They said relatively little during the beta. After some negative press, they turneed things around in December, but now have gone quiet again. Now, it's probably true that they've been more vocal than many large companies would be. However, first of all, they're not that large and almost certainly don't have the same bureaucracy to post something as a company like Microsoft probably has. But more importantly, I think they're basically asking customers to hang in there based on what the Echo will become. If you're asking people to do that you better be making visible progress and/or providing updates to your customers. Since the release, it really seems like the only particularly noticeable area of progress has been around finally getting recorded TV playback to what it should have been (at a minimum) at launch. That doesn't inspire much confidence in me.
post #5845 of 7607
Sorry Dave - I now remember that I promised I would upload my upgrade weeks ago.
I will do so tomorrow.
xnappo
post #5846 of 7607
Well said. I will carefully consider doing the same with my two in the next week if nothing ground breaking occurs in the mean time. I really have no idea why Ceton would have gone so quiet on this when they were so pumped in December with State of the Echo etc....a shame really.
post #5847 of 7607
I agree. I bought this thing as what it was marketed to be (the extender I had ”been waiting for”). I didn't buy it because I wanted another project to work on. Maybe that's what a lot of people on here wanted, but I don't care about the journey with this thing, I just want to be at the frickin' destination.
post #5848 of 7607
I got mine for the journey during the beta back in October but thought it would be at the destination by now. I'm keeping it as it is doing what I need it to do right now and think it will be made to do more in the future. It was definitely rushed to market though.
post #5849 of 7607
I also received mine in the first beta wave and had high hopes for what it could become but expected much more by now than they have delivered to date. I will be keeping mine but would not recommend it over an xbox 360 to any one considering one or the other.
I think Ceton owe all of us Beta testers a big apology for not delivering as promised. The only way I see any of us being made whole or happy would be to immediately come clean on the true future and State of Echo . Perhaps if there is a plan for the future they could at least offer us early adopters a deeply discounted option to purchase another one or too because IMHO this thing is no where near worth its current price and without Win8 & better file playback features never will be. Android support could be a good thing but to date it is just vaporware.
post #5850 of 7607
Win8? Meh.
It is a $100 add on now for WMC in Win8. I'll stick with my tried and true Win7. I'm pretty sure the installed base of Win8 will never reach that of Win7 because of lackluster PC sales as people switch to tablets and such. PC's running Win7 are pretty darn reliable and people don't even see a need to upgrade. WMC is in there for free but a lot of people don't even know about it because MS has it disabled as a default. I bet if it was on the desktop 3 or 4 years ago the amount of people using it would be much higher yet still.
