Originally Posted by Shark007
To assist those using my software for Extender playback, DO NOT install AC3Filter (or any Divx software). All required software is included. For Extender use, only one setting is required, enable the Divx MF splitter on the MKV TAB. Other functionality required by the Extender is tied to this one checkbox. My software is released in a Windows 7 version and a Windows 8 version. When Extenders are your playback focus, you must use the version that matches your operating system.
For those that need to know, I am working on supporting playback of FLV, MKV etc directly using DLNA (Play To...) - The xbox supports DLNA. At this time, testing is favorable and this functionality will be in my next release. (It is not included in today's release) This functionality will be enabled/disabled using the Windows Filetype Associations button on the Help TAB. The SUGGESTED settings will also enable this functionality.
Here's to hoping the Echo will support DLNA functionality also.
DLNA FACTS: Windows 7 restricts DLNA to Media Foundation components
Windows 8 allows DirectShow filters during DLNA playback meaning the LAV filters get used.
DLNA does not support subtitles.
To enable this you need to have the box not checked because the box says "disable.."
is". I have remuxed about 10 or so low bit rate MKV's + (non-HD) DTS and my echo crashes immediately.
