Originally Posted by
xnappo
Hmm - it certainly doesn't happen every time.
I will see if I can recreate it this weekend.
xnappo
I can make it do it every time. If I turn the Echo on and TV on and then shut the TV off, after a few minutes it will start cycling the processes on the HTPC and cause stuttering. Every time.
I came home for lunch and had a few minutes to look into the processes that are running. Here is a snapshot. These will start and then all MCX2 processes will dissappear from the Task Manager, then start again about 10-15 seconds later. You can see the high CPU usage, when the Echo is turned off I might see 25% at the most. When I turn on the Echo and it's doing this cycling thing, I will see 50-100% CPU usage.
