Originally Posted by shortcut3d
There is one specific Intel NIC that people are having difficulty with on the SiliconDust forums. http://www.silicondust.com/forum2/viewtopic.php?f=41&t=14076&start=30 Someone figured out the driver version one would need to play nice with WMC. Unfortunately, the Intel utility and some locations on their website do not have the latest driver. Try here http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18713&lang=eng
Also your router could cause issues. http://forum1.netgear.com/showthread.php?t=67681
Also try switching the Ethernet cable connecting your Echo.
Thanks for the info.
Kinda weird though. Checked my Intel Driver version number in Device Manager 12.2.45.0 8/10/2012 Followed the link that you gave me which pointed to driver Version 18.0 dated 1/11/2013
Installed the newer driver and sure enough Device Manager shows 12.2.45.0 installed. I double checked the inf file(s) that came with the download to see what version they showed and they were indeed 12.2.45.0 Strangeness.
Anyway, thanks again for the tip and I'll report back any changes.
