Originally Posted by
Raistlin_HT
Oh cool. Do you know off the top of your head if Windows offers something similar? That would make this moot.
There is the ClearType Text Tuner, but this only allows you to choose between RGB, BGR or greyscale rendering. Frankly, Windows' font rendering is rather poor.
OS X only has RGB font rendering options. (but it's far superior to how Windows renders fonts) By default, your only option is whether to use subpixel font rendering or not, as it runs on the GPU now. If you run it on the CPU, you have light/heavy options available, but they're still RGB.
Raistlin_HT
While I generally agree, the proof is in the pudding. There are 3-chip LCoS displays that pass 1080p resolution tests, so getting the alignment right is obviously possible. I assume the issue is that alignment changes over throw distance? So you'd need alignment calibration depending on where it's located?
It's nothing to do with throw distance, just the alignment of the LCoS chips in the light path. I've never seen an LCoS projector with anything close to perfect alignment.
Going back to that same page, here are three generations of JVC projectors (which are hardly cheap) compared with single-chip DLP for alternating black/white lines:
Any colour fringing with DLP is chromatic aberrations from the optics, with LCoS, it's primarily due to panel misconvergence.
Many people, including Joe Kane, have made the argument that "1080p LCoS" does not actually resolve proper 1080p resolution. After owning an SXRD projector, I'm inclined to agree.
Raistlin_HT
Certainly you are correct that single-chip solutions don't have to worry about that though. However with DLP, the side-effect is you need to worry about temporal issues due to PWM for color production.
Absolutely. My last high-end projector was a Sony SXRD unit, and I was disappointed with sharpness on it when watching 1080p content due to misconvergence. (and it wasn't even
bad misconvergence either) Right now I'm waiting for the price of DLP projectors using other light sources (LED/Laser/Hybrid) to drop before getting back into projection at my new place. (LED/Laser mostly eliminate the "rainbow" problem)
Raistlin_HT
Probably. Thankfully OLED and LED-based displays at least have the potential to eventually offer full color pixels. Whether it ends up being tenable or not remains to be seen though (either cost or performance issues).
I don't see it happening any time soon unfortunately. As I said before, I think we'll see the jump to 4K first, as that's a big jump in resolution and has the benefit of also reducing the visibility of the subpixels.
specuvestor
Yes it is technically possible, but like I said before, I am not too sure that you want a transparent monitor in your office
Not that useful for TV as it will diminish contrast unless you have a black wall
As others have said, there are simple solutions to that problem. Having a transparent LCD panel, or even a sheet of "smart glass" behind the transparent OLED panel would give you a switchable opaque background.
