AVS › AVS Forum › Other Areas of Interest › Camcorders › JVC GY-HMQ10U (small 4K 60p camcorder)
post #1 of 156
http://pro.jvc.com/prof/attributes/f...l_id=MDL102132
http://pro.jvc.com/pro/pr/2012/releases/gyhmq10.html
I'm a little nervous of the f/2.8 lens but then, this is still a very unique camcorder. Not a bad toy to own if you have 5 grand to spare. I want it!
post #2 of 156
That's brilliant! Don't be disappointed by f/2.8, in a 1/2'' camera that seems about right. It's easy to do f/1.8 with 1/4,'' but as you increase sensor size you need bigger lenses, which are naturally slower.
post #3 of 156
JVC did f/1.2 in a similar sized chip for their last year's top consumer camcorders so it can be done but they probably went to f/2.8 to keep it as sharp as possible so a trade off might have had to be made. Basically it may not shine when the lights go down but with plenty of lighting, this thing will definitely shine.
post #4 of 156
I want the same, but 1080p is enough, 50 Mbit/s is enough, and please no more than $2.5K.
post #5 of 156
Good point, another variable that can impact sharpness is zoom range, and they probably did not want a 3-5x zoom. If that's the case, they made the right compromise.
post #6 of 156
post #7 of 156
Here's the interchangeable lens version with a bigger chip.
http://prophotocoalition.com/index.p...rchangeable_l/
post #8 of 156
Very nice! What's the l x w on a 16:9 rectangle if the diagonal is 1.25''? (Trig is not one of my strong points).
Got it, using this calculator http://www.globalrph.com/screenwidth.htm
I got 1.09'' x 0.61'' (27.6mm x 15.6mm)
So it's about APS-C / Super 35mm size.
I want!!!
post #9 of 156
JVC introduced the GY-HMQ10U as an unnamed "concept" camera at CES a whole year ago. Evidently, the technology has been in development for several years, but remains too ahead of the market. 4k projectors and screens will exceed the content of most broadcast or entertainment media for several years, at least. Evidently, JVC is rolling out this device for that niche of people with an appetite to experiment ahead of the curve, but without the big bucks for a RED. Heck, the JVC cost barely more than what it takes to rent a RED. It costs less than some high-end DSLR systems (with lenses and extra mics).
It would not be worthwhile to shoot 4K video only to have to downsize it all to 1920x1080 resolution, or simply to stockpile 4K clips now as a hedge against obsolescence of "mere" HDTV, perhaps in 2020. Twenty years from now, people will not wimper that 1920x1080 looks blurry the way VHS, in retrospect, appears today.
Neither is it likely that 4k will become the bar for video display anywhere other than a theater, whether commercial or in the mansions of the well-to-do. Most of the 4k content will remain, at least for a while, upscaled 1920x1080 Blu-ray grade video.
That said, there are a number of things that make 4k video capture interesting, without any 4k display outlets at all. Most important, you could shoot action or stage subjects at wide angle, and then crop them to 1920x1080 and thus obtain close-ups or semi-close-ups without loss of quality and without need to pan or zoom. With key-framing, you could track erratic or unpredictable action and not need to jerk the camera frantically about in the quest to keep a player or raptor in the frame. Still photographers have this luxury all the time. Without 4k, a videographer can barely crop at all, no matter what the framerate or bitrate.
However, in order that the GY-HMQ10U fulfill this potential, realistically, the following conditions would have to be met:
1) Sufficient dynamic range so that details are not so muddled or blown out that the effective result is no better than usual HD.
2) At least some low light resilience. Will 4k with a 1/2.3" sensor be any good at all if shot in a dim gymnasium, natatorium, auditorium, or sanctuary?
3) Some tool to edit or crop 4k video that is compatible with the sort of i7 system a small pro or enthusiast is likely to have. If the hardware requirements are too high, or the workflow too complex, 4k just won't be worth the trouble, or just as marginal as 3D.
It would be ingenious for JVC to enable a buyer to employ the camera's own processors, in conjunction with a relatively ordinary computer, to perform some of the core editing tasks. Otherwise, my guess is that a buyer will have to wait for software that uses proxy files, or attempt daunting experiments with advanced graphics cards.
When AVCHD first appeared, it was frustrating to utilize on existing PCs or editing products. However, even in late 2006 or early 2007, one could already convert it to HDV MPEG2 and edit it comfortably on a 2 core machine.
If anyone obtains sample material shot by the forthcoming JVC machine, please confirm whether you are able to play, split, splice, key-frame, or crop the clips. Kindly confirm your computer specs, OS, and software.
If any JVC representative follows this forum, let me thank the company for introducing this innovation. However, may I cordially suggest that the firm develop more user guidance, encourage software publishers to roll out tools to work with the video files, and possibly develop firmware so that someone with a mere i7 system and 1920x1080 display might be able to employ the camera's chips as co-processors to allow for basic editing and file export functions. Alternatively, if the PAZ, crop, or conversion functions could be done with the camera itself, using an external HDTV as the display, and maybe a USB keyboard or mouse, that would be a great idea.
Not all potential buyers will have Dreamworks-grade workstations or a 55' LG 8k screen to work with. If the 4k camera delivers full value only under ideal light, that also constrains demand, unless the auxiliary costs are within reason.
Realistically, the best solution might be to employ the camera's own chips to perform edits or crops of the 4k footage, then export to a 1920x1080 format compatible with existing screens and editors. JVC could certainly embed such a tool in the camera, which could be used in conjunction with an HDTV monitor and mouse, in lieu of waiting 3 years for 4k-friendly software or graphics cards. I'd strongly urge JVC to include that sort of capacity in the camera itself. Otherwise, the camera will be like a plug-in auto without any plugs.
Meanwhile, I read that JVC will introduce an interchangeable lens 4k device by late 2012. Precisely what sensor size? A larger sensor might be nice, but not make it any more a "sure thing" than the GY-HMQ10U, unless there is an economical way to edit the output in a world where i7 computers or 1920x1080 displays are likely to remain the "high end" for the next few years.
BTW, has JVC (or anyone else) introduced a 1080 60p Blu-ray player? When, if ever, will there be a 4k player or disc media? Exactly what 4k playback driver did JVC use at its CES booth?
post #10 of 156
The PS3 is already capable of playing back JVC's 1080 60p files and copying that same file from Watch.impress 4 times, I'm able to play all 4 files smoothly in Premiere CS5 and I have just 1 quad-core (i7) processor and my hard drives aren't in a raid. Granted I also have 12 gigs of RAM and a 470 NVidia card. People have talked about playing back 1080 60p files from Panasonic and Sony camcorders on the newer Panasonic and Sony Blu-Ray players. Some people even use their computers nowadays with their HD TVs hooked up to it through HDMI.
I'm assuming playing back 4K files should be just as smooth as playing back 4 1080 60p files at the same time from the JVC PX1/PX10 camcorder. I guess it looks like I wont have issue editing the files. I might be able to edit a couple of 4K streams at the same time smoothly for a music video although I'm not so sure if I can do 3x 4K streams on my system smoothly. I might need a raid for that and possibly 2 quad processors especially if I'll be adding effects.
One of the reasons I'd be interested is because of music videos. I'd be able to zoom into different parts of the image for a final 1080p output. I'll also be cool to have 4K content now. I've seen a ton of arguments in the past about HD not being needed and hard to edit but I was still one of the first to get the Sony HC1 camcorder in the summer of 2005 and I'm very glad I did.
Their will surely be a market for this camcorder either for people who want a more affordable way of shooting in 4K without spending much more for a fully functional Scarlet or for people who will use it as a second or third camera to a RED or Sony F65 for example. The fact that the low light might not be good is one of those trade offs. It's hard to find a camera or camcorder without trade-offs.
Still, I'm definitely looking forward to the first tests to see how it really is.
post #11 of 156
Yes, TVs will never get more than 1080p like we will never need more than a 5 GB hard drive on our computers. Technology is about to come to a standstill! Seriously though, I have seen a 4K TV and the quality blows 1080p away. Makes it look ordinary.
I predict that we will see 2160p TVs become available to consumers within 2 years.
post #12 of 156
With 12 Mbit/s broadcast, 9 Mbit/s satellite and 2-5 Mbit/s YouTube there is barely enough bandwidth to make 720p watchable. Netflix chokes on the evenings when I try to watch a 10 Mbit/s show, it can only pump about 3 Mbit/s in peak hours in my area when everyone is using the Net. Hence, I don't need 4K neither I care.
I've read on another forum that 4K may be actually quite useful for reporters for framegrabs. And, as pointed above, virtual panning. So, I don't think nor I wish for 4K to trickle down to consumer devices, but it will expand shooting options.
post #13 of 156
Well I mean Blu-ray/home theatre market will go 4K, not broadcast..... yet!
post #14 of 156
Looking forward to 4K myself. I bought a Sony HC3 HDV camcorder around 6 years ago. Glad I did, being able to finally get some HD of my family, events, etc, etc. 1080p looks good, but having used a projector for 7 years now, I am ready to step up to the higher resolution. Might have to film in 4k first, and then get a 4k display, but at least I'll have 4k material ready. Kudos to JVC for leading the way.
post #15 of 156
The HC3 is interlaced only. Get a newer Sony or Panasonic and you will get twice the resolution at 1080p60.
post #16 of 156
Editing original 4K files from the camera may be another thing, but playing 4K back while at the same time downconverting to 1080p doesn't seem to tax today's PCs much. Even my laptop can do it (2.8GHz T9600 Core 2 Duo). Mind you, I'm talking about the 4K files from YouTube at 30 fps, which are highly compressed (the best I've seen averaging only 19.7 Mbps). (BTW, downconverting to 1080p results in a much better looking image than you'd expect from such a bitrate because of pixel averaging.) Playing back 4K files direct from the camera, which are not as highly compessed (I'll say - 144Mbps!), probably takes more muscle, while editing would take even more.
Someone has to take the lead, thus creating demand for the processing power and efficient progams we'll need for a complete (and affordable) 4K workflow. Kudos to JVC.
post #17 of 156
Ungermann,
All that I know my friend, I have some of the newer camcorders. 4K is what I really want for the future.
post #18 of 156
Panning within the camcorder seams like a neat feature even though doing it on a computer will be better.
I might want to rent one of these for a gig one day. I'll just have to make sure it's either for outdoor shooting during the day or indoors with plenty of lighting.
post #19 of 156
Panning or cropping 4k clips with a computer might be nice, but what CPU, graphics, or RAM specs would be needed?
To edit the 4k h.265 MP4 files in native format may be simply impossible, even with a high-end i7 machine. Creative Suite or FCPX users probably decompress to some format that uses oceans of disc space. Until some sample clips appear in their native form, there is no way to know. People familiar with RED workflow may figure out a solution, but not eager to spill the trade secrets. By 2014, perhaps several software publishers will offer means to edit, without decompression to huge intermediate files, by means of proxy files, a bit the way Corel allows people with slower PCs to edit AVCHD.
Consequently, the best near-term means to edit 4k, without spending a fortune or waiting until 2014, would be if the JVC camera itself came fitted with some in-camera edit functions, or else a way to tether it to a PC to use the camera chips to boost the processing or graphics strength of an on-computer program.
Otherwise, I'd fear ending up with a "white elephant" camera that would be obsolete, or superseded by cheaper & better models, before I ever found a way to edit 4k.
post #20 of 156
This is a $5,000 camcorder mostly aimed toward professionals and I'm sure people who have some interest in buying one either have a computer that can handle it or will probably use Cineform, etc if their computer can't handle it but have a raid set up. Heck, if their willing to spend 5K on a camcorder, than chances are, some of them might be willing to spend some money and update their computer. This particular model is definitely not aimed toward your average consumer. Once consumer versions come out that are less than a grand, I'm sure computers that will be good to edit it will costs much less. Still, I would not be surprised at all if my computer that was built in 2010 for about $2,100 will be able to do at the very least simple edits without issue but we'll see.
From what I've read, the camcorder is recording 4 separate streams onto 4 separate memory cards and each stream is around the same bit rate as what you'll find in JVC's 1080 60p camcorders so that's why I would assume it might not make a difference. I would also assume that JVC might provide software that stitch all 4 streams. Now if 4k Streams would be an issue for my machine than as a trade off, I can put all 4 un-stitched streams in the time line. At the same time, theirs always the possibility that the H.264 codec is more advanced and each stream would be slightly harder on a computer than the streams from JVC's 1080 60p camcorders so perhaps my computer might not be as smooth (obviously that would give me a headache). For sure if I had a raid set up, I could be using Ciniform. Now if I had 5K to blow, I might as well update the computer. Might not be worth it just for a rental. I also wouldn't mind renting a Sony F65 for a gig but your talking a different rental price range.
I'm very certain that a lot of the people who are interested in this camcorder will be doing projects with it right away and not wait until 1 to 2 years to work with the files especially for the people it's aimed at. Again, this particular model is not for your average consumer.
Thinking about it over, people shooting in 4K 24p wont have as much issue as people shooting in 4K 60p. Writing this post have gotten me anxious to take 4 HD streams and export to 4K 60p and 24p at 144MBPS using Main Concepts H.264 codec. It wont give entirely accurate results since the H.264 codec can vary greatly but it''ll be fun to experiment and see how those 4K files play on my computer.
post #21 of 156
Doing some experimenting I see that when I export it to 144Mbps, Premiere CS5 thinks it's an audio file when I put that into the time line for some strange reason but when exporting to something like 100Mbps, it's normal. I''ll have to look into that but anyway, as expected the 4K 24p file plays perfectly fine on my machine and stacking 2 to 3 4K clips aren't bad but I wont go to that extreme for a project I have in mind. More like 2 to 3 1080p files and 1 2160p file. Granted I did not do any kind of special effects. These are H.264 files from Main Concept and in the past when I played 1080 60p files from it on my PS3, it would struggle but when I play 1080 60p files from JVC's camcorders, it's fine.
Hopefully it wont be long to get the actual samples.
post #22 of 156
Here is a better clip showing footage of the GY-HMQ10 at CES showing footage on a 4k Toshiba set. Around the 1:50 mark is some footage shot at night, which looks pretty good. Wish the camera filming the clip was a 4k cam, and our displays were 4k....... patience, patience.
post #23 of 156
I wouldn't be surprised if we'll see the Canon 2/3" version later this year. Hopefully by the time NAB hits.
On the 25th of this month, I'll have the privilege of seeing the Sony F65 up close at a show. It would definitely be nice having both the f65 and the HMQ10 on a video shoot. Use the F65 for tripod/dolly shots and the HMQ10 for handheld shots.
post #24 of 156
I too, got an HC3 when they first came out, am glad I got so much family footage on HDV when everyone else was using DV or even hi8. At the time, I had a slow pc, no idea of how or when I'd ever be ever be able to edit the stuff- I simply filmed and stored, filmed and stored. Now, I have a few hundred hours of tapes, a six month old Sony Vaio laptop with a bluray burner- I got my work cutout for me! Am currently using a Canon HV40, yup, still clinging to HDV, despite those who say it is archaic.
A 4k camera? I'm listening- wonder if they'll come out with a 4k camera that does 3d, that could make my living room look like the holodeck on the Starship Enterprise!
I currently watch everything on what some would consider an archaic set- a Samsung 72" DLP. Hey, at least it is over 70" in size!
post #25 of 156
Question to "dclark' or anybody else familiar with HDV file format:
What is the process/workflow of creating Blu-ray discs from HDV format tapes/files?
My older friend who lives in Europe, bought himself a Blu-ray burner, but is struggling with the whole process.
I, myself went straight from SD miniDV camcorder to AVCHD (2/progressive/60p) camcorder and don't have any experience with the conversion/work flow from HDV (miniDV) to Blu-ray discs.
Any information and/or advice will be appreciated.
post #26 of 156
...but remains too ahead of the market.
Ahead of which market? Obviously given that there have been 4K and 5K capable cameras out for some years now, the market is there, JVC is making it more affordable for both the Pro, Prosumer and average Joe so it's an all around win.
I'm not sure about the 'several' years, content manufacturers are already working on delivering 4K media within the next couple of years if not by 2013. Sony is a huge backer (Google it).
I wouldn't call it niche, I'd call it cutting edge if it delivers on the quality end, just as I wouldn't have called the Red One a niche product when it was introduced. Even the smartest shooter would go with the the less expensive option vs Red again if it delivers on the quality end.
Laughing at that one, believe it or not there are people who still deliver 480p content and shoot on Red or film or 1080p just to downsize. Obviously you don't shoot because you wouldn't have made that statement. Capturing @ 4K and delivering even down to 480p would produce better results than if you captured @ 1080p and downsampled @ 480p again as long as the quality end of the camera holds up and all else being equal.
I would love to peek into this crystal ball you have, you're making a lot of predictions based on what? Manufacturers are alwasy willing and ready to adopt the 'what's hot' next product for consumers to sink their money into with the marketing team hyping "4K it's 4 times better than your 1080p TV!" You think Joe Consumer won't jump on that if the price point is right? I know I would and am when it becomes affordable. The first 1080p sets introduced were ridiculously priced at $7-10K! Many people bought then and now the trend is 1080p. Same will happen to 4K, guaranteed, that's the tech track record.
It would be ingenious for JVC to enable a buyer to employ the camera's own processors, in conjunction with a relatively ordinary computer, to perform some of the core editing tasks...
Will never happen, that would give hackers and opportunity to tap into the JVCs Falconbrid processor directly. That idea has never happened in the history of product manufacturing for cameras as far as I know.
Primiere has been able to edit 4K proxy files for years as well as Avid and a few others and has been able to use GPU computing to accelerate that process for the past 3 generations.
Just as video tech is advancing so is CPU tech and it's actually advancing even faster. Intel already has roadmapped it's next level of processors and you have affordable hexacore I7s as well that you can do a double configuration on for either and 8 core or 12 core computer. Apple has a 12 core monster computer that should be able to handle 4K video.
Mentioned it before, they're in the works.
I'm not sure what you mean by 'driver' but they had live 4K and pre-recorded 4K playing straight from the camera to 4K displays via the HDMI outs.
Editing 4K is available now, obviously. Many indy directors and prosumers are shooting 4K and editing on relatively standard PCs and Macs all the time. The movie Monsters was shot on Red in 4K and edited on standard Mac, it's possible. This isn't the first 4K solution out there.
I'm not sure why you have so much negativity and angst for this camera or why you decided to post what you did, but you haven't done a lot of research or don't have an understanding of what is possible now or in the short term with cameras and computers et al.
I for one embrace all new advances in tech especially in the area of cameras and computers.
JVC set the world on fire when they introduced the GR-HD1 back in 2003 and they're doing it again with the GY-HMQ10. The world will catch up in relatively short order.
I second that. :-)
Waiting with baited breath myself!!
Cheers.
post #27 of 156
Hi
A rather sweeping statement! Panasonic camcorders do exactly the above so you can off load the processing of H264 to the camera from your PC to speed up conversions.
Regards
Phil
post #28 of 156
Originally Posted by Philip_L View Post
Hi
Regards
Phil
Luckily I ended my sentence with "as far as I know...".
The link you embeded in your post is a link to a remote control, not sure if you had the wrong URL, but that has nothing to do with anything.
As far as Panny cameras doing the offloading for conversion I don't think it's being applied like you think. The PC recognizes the camcorder as a drive not an external processor. I think that Panasonic has a feature embeded in the camcorder that allows the camcorder to downconvert the 60p footage to something more viable (MPEG-2, AVCHD @ 60i etc). Many camcorders also do this and have been able to for some time without the fancy labeling of Conversion Assist.
I don't think you have access to the camcorder processor via a USB 2.0 connection to help speed up processing for the PC, like for example Premiere Pro CS5 uses the GPU from NVIDIA graphics cards along with the CPU to help with conversions and processing, I don't think that's going on with the camcorder connected.
I'd love to be proven wrong because this may be the best thing since sliced bread for people with older PCs.
post #29 of 156
That was put their atomically by the forum to help get the site some extra revenue. I'll sometimes happen from time to time.
post #30 of 156
LOL, interesting. Things sure have changed. :-)
Thanks Paulo.
  Back to Forum: Camcorders
