These forums have been a lot of help to me recently, so I just wanted to share my opinion of the Q5.
I received it yesterday, but I spent whole day playing with it
First of all it is a true marvel considering the performance and what's been packed in the size of it.
Brightness is great, colors are vivid and image is sharp.
minor flaws: (that does not impact viewing pleasure and I can get used to it over time)
- warm up focus thing
- remote button layout not intuitive (makes you look at the remote every time you press button)
major flaws: (breaks the viewing pleasure)
- distinct judder (not sure how to call it) during fast scenes or camera movements especially noticeable in soft gradients like faces and on blurry objects.
I think the issue is called Dynamic False Contouring from the thread HERE and looks like the image HERE
I will try different input sources to see if the problem is still present. I will also take a picture of it.
Anyone else experiencing something like it?
- the fan noise it makes in "Normal LED" mode, ECO mode is fine but the image is too dim. It is annoying when projector is 1 - 1.5 meters away. If I will keep the projector I will make a fan mod for it (add a silent one in front of air intake)
