Hey everybody,
I'm new here and this is my first post, I guess. I sometimes pick up electronics I find on curbs because it's surprising how many times the item will be working or repairable.
Recently, I found an HDTV that I couldn't pass up. Of course, you know from the title, it was a KDF-50WE655 LA3 or in other words, a Sony LCD Projection TV. This TV was in excellent cosmetic and was perfect except for the fact that the screen remained black if it was turned on. However, upon turning on, the power button flashes green 10 times before turning a solid green.
I looked up a guide of Sony's key for this self diagnostic tool they built into the TV. This is what it said: "Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board."
My problem is that the closest thing to a "D" board the Sony Operation Manual mentions for this tv is the "KD" board. Is the "D" board part of this one? Or is there something I'm missing...
Here is the link for the guide (the "KD" board is presented around page 55):
http://www.scribd[DOT]com/doc/47828627/KDF-42WE655
Thanks for any help in advance.
