AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Panasonic DMP BDT500
Panasonic DMP BDT500 - Page 36
post #1051 of 1215
Originally Posted by mfrey0118 View Post
I just downloaded a 1080p BD rip of "Savages", a 14GB MKV file, transferred it to my new 32GB 3.0 USB flash drive and plugged it into the 500.
Plays perfectly, quality is outstanding, almost BD like. Audio is native DTS 5.1.
This is sweet, up until I got the 500, I was having issues with my equipment's restrictive media file playback features...no longer. cool.gif
I've had this player for a few months now and I really like it. Much better than my 210 that got retired to the bedroom.
THIS is great to hear indeed!
Have you played back .AVI files or other with as much success?
~ Big Marcus
post #1052 of 1215
~ Big Marcus
.AVI seems to do well, although sometimes there's a sharing or security conflict for some reason, probably because it's a torrent...biggrin.gif
.MOV and .MPEG are real hit and miss.
post #1053 of 1215
Originally Posted by Angler55 View Post
From what I've gathered, reading the "Official Panasonic DMP-BDT220/320/500 Owners Thread", some folks are having problems with MKV's using DLNA with the Panasonic players and some folks are getting perfectly good results. I don't use that feature with my BDT500 but not because it won't perform those functions as I got mine for it's other features like 7.1 Analog Audio Out which comes in handy for me. Noboby else is making a player anymore with that feature at the price point of the 500. Although I know very little about the DLNA features of these players, it seems the Panasonics are touchy with how they are set up to perform these functions but if done right they will play MKV's just fine.
Al
MKVs are just containers. You need to determine what codec is being used within the file contained in the MKV.
Popular codecs used by BD as an example, include mpeg4 AVC, VC-1 and Mpeg 2. That's just the video. Then there is the audio .....
post #1054 of 1215
Ordered and on it's way... :thumbup:
BigMarcus ~ EVO 4G LTE
post #1055 of 1215
Fyi.... I'm coming from a LG 670 that seemed to have firmware updates every other day! :what:
When I receive my 500, what if any should I download or not????
post #1056 of 1215
There is no problem with the current 1.49 firmware.
S~
post #1057 of 1215
It's no wonder I haven't used the this feature on my BDT500!
I really should take some time and try to learn something about files. I've had a computer for almost five years and haven't really learned much about saving things and that's a little silly because I'm sure I could absorb this stuff if I gave it a chance. I'm not getting any younger so if I don't try this soon in a couple years I'll be too senile. I've even got things on my computer right now that I can't open because I haven't bothered to try and change the format (or codecs I guess).
Well, thanks for giving me a start apw2607 (I think). Maybe if I decide I enjoy messing with these files I'll be able to talk myself into buying a new multi-media computer!
Al
post #1058 of 1215
Al
I use AVS Converter for years. It works flawless and allow to convert files between all modern coding systems. It is a good and fairly easy way to start for beginner. There is a trial version you can download directly from avs4you.com website to see if you like the job and it is worth your time and effort. Good luck!
post #1059 of 1215
Thanks esdwa, I'll look into that.
Al
post #1060 of 1215
I will soon be purchasing this BDT500 this March our unless a newer model is released. My friend in Colorado has compared the video quality towards Blu-Ray's with the Denon 1713 and the Integra DBS-50.3 and stated that the Blu-Ray's seem to be much sharper on this player. The images seem to jump right off the screen towards you as he explains it. Any comments on this to anyone owning this unit.
Also my friend is a heavy collector of DVD movies and say's the DVD movie playback is top notch. Also, any of your comments on the DVD movie side would be greatly appreciated.
I've seen them sold for under $300.00 on Amazon.
I will be using the player for video processing only. I'll let my pre-amp do all the audio processing.
Peace to all.
post #1061 of 1215
Al
You are welcome. There is also DVDFab, also versatile and easy to use tool just in case you look for competitor.
Beyond these there are lots of free tools that may require advance knowledge to properly configure installed codes.
Dvdconverter and DVDFab are two that should work "right out of the box".
post #1062 of 1215
You can also try Freemake Video Converter, which I use.
post #1063 of 1215
Hi guys.
I have kind of a strange question. I can explain in detail if anybody really wants me to. For brevity's sake:
I have a 3.1 configuration, front L/C/R & Sub. Will the BDT500 decode and downmix 5.1 & 7.1 to 3.1? The manual is somewhat vague about this. The heading "Analog Audio Output" on page 30 seems to say that. Was wondering if anyone can confirm?
http://service.us.panasonic.com/OPERMANPDF/DMPBDT500-MUL.PDF
Analog Audio Output
You can set the optimum multi-channel surround
sound for your speakers from this unit when the
settings cannot be adjusted from a connected
amplifier/receiver with AUDIO OUT terminals.
Select “2ch (Downmix) + 5.1ch” or “7.1ch” and
then set the following options.
– Speaker presence and size
() – Delay time ( )
– Channel balance ( )
To finish the speaker setting
Select “Complete”.
~Alden
post #1064 of 1215
Originally Posted by aldenf View Post
Hi guys.
Analog Audio Output
() – Delay time ( )
Select “Complete”.
~Alden
Yeah, that can be done fairly easily. The BDT500 set up menu lets you set the rear surrounds to invisible and take them right out of the picture so you can run your tone test for just the front, center and sub. You can actually take out all the speakers except the front right and left. Hope this helps.
Al
post #1065 of 1215
For advanced users wink.gif :
Is there a way to disable the "Whiter Than White" or "SuperWhite" option on this BD player ?
Because on Contrast patterns I've tried, I can see all the bars through ~250 (instead of 235 normally without WTW or Superwhite option enabled if such existed on this player).
Did you guys notice it too ?
Like this :
And, for those who calibrated (with a meter) their TV, or VP, along with the BDT500, did you use the Adaptive Chroma feature ?
There is good and bad with this option apparently.
Thank you.
post #1066 of 1215
Like this :
Thank you.
You can't expect your television to be calibrated properly when using your BDT500 unless you calibrate it with the BDT500. I set up my TV for cable on one of my inputs and also set it up on another input that my BDT500 is using. In other words, because I don't know much about this, your television needs to be calibrated differently for all sources like gaming, blu ray, cable and so on.
Maybe someone who knows how to explain this will chime in but I think that's what you're talking about.
Al
post #1067 of 1215
Just if someone has the opportunity to compare flac decoding quality of the bdt-500 vs the oppo 103 and has some returns on it ... i'm hesitating between these two,
(talking about analog qualities) !
post #1068 of 1215
Do you believe a Panasonic owner would buy oppo or the other way around? What is oppo anyway? Just kiddin, dont have to answer. Cheers.
post #1069 of 1215
Like this :
Thank you.
to calibrate your tv. you need to use the settings on the tv and not the player settings. there are calibration discs that you can use or that come with the blu ray or dvd? some disney titles or t2:skynet edition.
I would use this link. it will help you understand the calibration process.
http://www.spearsandmunsil.com/
Jacob
post #1070 of 1215
Well... Thank you, but I know what calibration is and that is not exactly what I asked.
I have another question though : is the "SUPER RESOLUTION" option only made for DVDs ? Or is there an impact on BDs too ?
Edited by mlg33 - 2/4/13 at 9:16am
post #1071 of 1215
If you're calibrating the TV from the BD player, you should turn all processing off or to 0.
1. Super Resolution should be 0, only applies to DVD.
2. Turn Advanced Chromo processing off
3. HDMI value to 4:2:2, 4:4:4 (auto) might be why you are seeing the white above 235. I only use 4:4:4 (auto) with 3D.
S~
Edited by teachsac - 2/4/13 at 3:33pm
post #1072 of 1215
Will try that out.
Thank you.
post #1073 of 1215
Does any one have problems with layer 2 switch?
My bdt500 rakes really long time and some Times freeze and just acting alittle wierd compered to My older bluray player.
Sorry My eng.
post #1074 of 1215
Sorry My eng.
This is the 21st Century. There are NO LAYER Switching Problems.
YOU HAVE A BAD PLAYER - RETURN IT
post #1075 of 1215
No layer switching noticed with my 500 either....
post #1076 of 1215
I have the oppo 103 and the panny 500 and the oppo is going back. The oppo has the sharpness HDMI 1 issue acknowleged by many owners which may or may not be resolved by firmware update. Also, to my ears, I prefer the analog sound for 2 ch on the panny over the oppo. 2 ch Flac also sounds great on the panny via analog. I am impressed with bluray and dvd play back. The remote is not an issue for me since I have a marantz programmable touchscreen. I use a panny plasma, JVC projector, Integra 80.3 A/V pre pro, definitive tech speakers and subs and an ADA MPA-501 5 ch amp. My system is a 5.2 configuration. Just FYI, the oppo also automatically starts playing a movie left in the unit, no way to disable it either like the panny. The panny 500 is an amazing machine to me, I'm not into internet streaming, use internet for firmware update only...I wanted a machine that had top notch audio and video, Flac for me is an added bonus....But, I'm really not surprised that it's a panasonic, back before bluray, the best dvd player I ever owned was the panasonic RP-82 (if I remember correctly, been a while). smile.gif
post #1077 of 1215
I'm with you 100 percent. My good friend buys many different blu-ray players; or should I say universal players, to test out. He has a very large collection of DVD's from the first years movies came out on DVD's up until now and in his test of the 103, he found that after two hours the video processing chip starts to overheat and the movie quality starts to diminish or should I say, "creates a lot of noise". I was going to get the 103 as he's told me and from the great past reviews that the 83 and 93 were exceptional models. I don't know what happened to Oppo lately. Anyway, he happened to try the Panasonic DMP-BDT500 and for the price of that unit, he can't believe how much better his DVD's and Blu-Rays are. He says there much sharper and for under $300.00, you can't beat it. So, I'm eventually going to get the 500 for my system and use it for just video processing and I'll be using my DHC-80.3 with the DTA-70.1 for just the audio processing with the 'THROUGH' setup feature. He also tried the Denon 1713 but had to return it cause it had issues with the DVD tray. I personally like the McIntosh 891. The performance is great but not worth the price and it doesn't do 3D but I really don't care about 3D as of right now. High priced gear doesn't always mean it will perform the best or is the best. And since I purchased a Panny TC-P65VT50, I'm sure the 500 will blend perfectly. On another note, so you like Def. Tech.? I just purchased 7 of their speakers for a 7.1 setup along with a JL Audio Fathom F112 sub. I will say that Def. Tech. has fantastic customer support as I've dealt with Chet and Thomas Baust on may occassions and they've always gone out of their way in helping there customers. A great speaker company. Well I wish you luck with everything. Take care and have a great year. wink.gif
post #1078 of 1215
Hey Cigarjohn47, Yeah, I really enjoy definitive tech sound and I completely agree that they have great customer service. The oppo 103 was my first oppo and was sort of a let down, IMO, it didn't live up to ALL the hype. Not that it's not a good unit, I just expected more than fancy packaging. Now the panny 500, so far, that thing has been a little beast! biggrin.gif
post #1079 of 1215
That's great to hear. After the construction people get done with building my custom wall unit for my equipment; which should be finished by March, that's when I'll be purchasing the 500 for my system. Though I use to be a heavy DVD collector, but I've already traded in my old DVD's for Blu-Rays. Though some of my older DVD's can't be upgraded. But that's okay with me since the video processing in the 500 is fantastic as I've been told by my friends who purchased this unit. Though, I still use an older DVD burner, Pioneer DVR-LX70. It still produces exceptional quality DVD coding. I keep it around since it's a Singapore model issue and is also a region free player.
I've used Def. Tech. subs before and had excellent luck with them. My new system build will be of a different genre. More of a contemporary look. I purchased three RCS II's for my front L, C & R and four RSS II's for my side and rears. There in-ceiling speakers that produce the effect that they sound like your listening to tower speakers.
I also had friends who had amps costing over $6k and when they heard the Integra DTA-70.1, they were astonished with it's sound quality at there price point. So I'm going with the DTA along with my DHC and XLR connectors. Also, I was recommended by JL Audio to use seperate SurgeX Surge protectors for my sub and amp. And one of my good friends who's always testing universal players out, said that after testing the Integra DBS-50.3, the blu-ray quality on the Panny 500 was much sharper than the Integra. And the menu system is much better along with BD-Live and internet surfing or streaming if your into that kind of stuff. So I'm staying with his recommendation and I'm getting the 500. Though, my VT50 is another story and I'm very mechanically inclined but I'm paying a professional to do a custom calibration of my Plasma. Well, nice talking to you. I wish you the best. wink.gif
post #1080 of 1215
It's a great player!
My only issue is with the remote...wish it was better. Menu selection seems poorly designed.
