AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Panasonic DMP BDT500
Panasonic DMP BDT500 - Page 28
post #811 of 1791
Originally Posted by drhankz View Post
I own the S790 and friends - JOEROD - owns both the S790 and BDT500.
My two cent recommendation is the S790 for the best available PQ and
Streaming Support.
Is there any difference in the transport / quality of the drive tray? My BDT210 is very loud when playing DVDs, quieter for Blu-ray but still can be loud.
post #812 of 1791
My 790 is not quiet.
S~
post #813 of 1791
From comments here and elsewhere, the mechanical noises of current generation Sony players vary from unit to unit. It's not surprising, considering that they're doubtless using lowest-bid mechanisms.
post #814 of 1791
Originally Posted by shadylpete View Post
Hey, I'm looking to upgrade from my PS3 and use something else for BDs instead, I want to see if I can get a better picture and be able to watch the 3D titles i own with TrueHD because the PS3 can't decode that on 3D titles.. My first choice was the BDT500, but is the picture quality that much better or is it a marginal upgrade? Would I be better with the Sony S790 or Panasonic BDT-01? (Which doesn't get talked about much around here)
Yeah I would be interested to see peoples thoughts on this too? A week ago I upgraded from a 42pz80u to the p50st50 and I think I need to move on from my ps3 to a dedicated Blu-ray player. I know I need the dual hdmi's because I have a Denon 1610.
post #815 of 1791
In operation the S790 and 500 are both quiet, but the Panasonic is a little noisy when opening as compared to the Sony.
post #816 of 1791
I'm thinking about getting one of these but have one question. I have a 3D Plasma and a 3D AVR. I'm running a high speed HDMI from the AVR to the Plasma but have a 1.3a from my BD to AVR. In getting a 3D blu-ray player do I need to get a high speed HDMI to go from BD to AVR?
post #817 of 1791
As you know, cables are no longer labeled 1.3, 1.4, etc. Certified 1.3a cables (under the old rules) are high speed. Should work just fine. Most of my cables are 1.3.
S~
post #818 of 1791
S~
Mine wouldn't work with a 1.3 cable. I had use a high speed cable to get the 3D to work.
post #819 of 1791
Hi, Does anyone know of an alternative Panasonic remote control (older model, I would guess...) that would work fine with the 500 that is back-lit? Thanks!
post #820 of 1791
Any universal will work fine with any panasonic disc player. The harmony 600/650/700 and Xsight 12G/18G are good choices. I don't know of any panasonic remotes that are/were backlit. But if you find one, it should work most of the functions since all panasonic disc players and recorders have used the same codes for at least 10 years. Any particular reason you want a panasonic remote rather than a universal? A typical universal will let you put any function on any button. Ones with displays are especially useful.
post #821 of 1791
It will typically depend on the distance, i.e. a Category 1 cable ( what I believe you are calling 1.3 cable ) should still work for 3D if the distance is short enough... If not, it was likely a very poor quality cable that was probably barely making the Category 1 specs...
post #822 of 1791
Category 1 would not be equivalent to 1.3. Category 2 would be 1.3 or high speed. Is it possible a 1.3 cable didn't work with 1.4 and 3D? Sure. The High Speed cable I got with my Oppo would not work with 3D and struggled with 1080p.
From HDMI.org:
•Standard (or “category 1”) HDMI cables have been tested to perform at speeds of 75Mhz or up to 2.25Gbps, which is the equivalent of a 720p/1080i signal.
•High Speed (or “category 2”) HDMI cables have been tested to perform at speeds of 340Mhz or up to 10.2Gbps, which is the highest bandwidth currently available over an HDMI cable and can successfully handle 1080p signals including those at increased color depths and/or increased refresh rates from the Source. High-Speed cables are also able to accommodate higher resolution displays, such as WQXGA cinema monitors (resolution of 2560 x 1600).
S~
post #823 of 1791
all my cables at home inlucding the 35ft HDMI cables are 1.3 high-speed cables. They pass through 3D signals no problem.
post #824 of 1791
Nope, it was 3'. Cable is Monoprice high speed. The Monoproce 1.3 cable did not work. But of course we're talking HDMI so YMMV.
post #825 of 1791
Monoprice, I have too many problems with that brand, especially with anything beyond 10ft.
post #826 of 1791
I just was hoping to spend very little, as older or used remotes can get pretty darn cheap compared to decent universals. That may be the way I have to go in Panasonic hasn't offered back-lit ones. Thanks for the reply!
post #827 of 1791
From HDMI.org:
S~
You are correct, I meant Category 2, but the point was that I don't believe there is any such thing as a 1.3 cable, i.e. they are either Category 1 or Category 2 per the specs you post above.. It is possible that a Category 1 cable would work at Category 2 speeds at short distances but that depends on the quality of the cable, etc.
I only use use HDMI over very short distances, i.e. 3 feet minimum to 4 feet maximum and my 7-8 year old HDMI cables worked fine with my Panasonic 500 BluRay player and Panasonic 65GT50...
post #828 of 1791
Yeah, their quality control isn't the best. I've had a couple of bad cables but they're so cheap it isn't even worth returning them. I've used their big fire hose HDMI cable with the braiding on a 20' run with no problems. They also have just come out with a high end line of HDMI cables.
post #829 of 1791
For the 3d settings, is it best to leave the distance defaulted to -2 and screen type to round?
post #830 of 1791
I would like to know this as well. Tks.
post #831 of 1791
[bump]
I am also curious...anyone?
post #832 of 1791
I hate to be a stick in the mud, but the 3d setting is going to be a matter of personal taste. I assume the -2 setting is probably optimized for Panny TV's- or what Panny thinks would look the best in most situations. It's hard to say what will look best on your system. Play around and see what you prefer. In fact, you might have to change the setting depending on the source, so there really is no right answer.
Don't be afraid to experiment!
post #833 of 1791
NETFLIX CONNECTIVITY PROBLEM SOLVED:
Sorry if posting a reply to nothing is not the way to get some hopefully helpfull information out on a fix I did with my Pany 500.
FYI: my 500 suddenly would not connect to Neflix. It had been working just fine for the 2 months or so that I have owned this player. To make a long story short, I went throught the contact Netflix exercise, and my service provider "frontiernet.net". The latter shuffled me around like a hot potatoe because my questions were above their experience/knowledge. However, the 2nd pass-off clued me into the website "portforward.com". I have not checked it out yet, but supposedly information on reconfiguring your modem for better throughput for gaming and download (Netflix) apps.
Anyway, hacking throught the various 500 screens did not provide any errors, just the I.P.s, connectivity tests all passed, etc.
So when I was satisfied my service was OK, I deactivated the 500 player's Neflix connection. I had to do this several times before finally getting the activation screen. As you know the pop-up alpha-numeric is a real pain in the xxx way to punch in the email and password for Netflix. But I reactivated, and wow-la, I have Netflix streaming again.
Netflix gave me the deactivation sequence. Find the arrow key pad with the "Keys" button. Here it is:
When the Netflix connection times out, you should see a gray pop-up. Do the following:
Use the following steps to deactivate the Netflix application on your Panny 500:
1. Launch the Netflix application.
2. Using the arrows on your controller, enter the following sequence:
o Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up
3. Select Deactivate.
4. Select Yes to confirm.
5. Select OK after a message reports that the device has been deactivated.
o This may take up to a minute.
6. The application will display a red screen for few seconds and then return to the "Are you a Netflix member?" page.
o Note: You must reactivate at this point without quitting the application for the deactivation to take effect.
Next time, I will not hesitate to deactivate/reactivate. I hope this does not become common place. I suspect the Panny 500 lost its mind. But it offers no clue as to what email and password it is currently trying to log into Netflix with. So this is a guess.
post #834 of 1791
Panasonic DMP-BDT500 Remote not Controlling/Communicating with Player
I just received and installed this player, but the Remote does not seem to function. I can turn the unit on with the button on the top left of the player, but not with the remote. When I turn it on, "SETUP" appears on the front panel of the player and "Select Language" appears on the video output. However, I can't find any buttons on the remote that communicate with the player in any way. I have also tried replacing the new batteries that came with the remote with another set of new batteries, I just purchased.
I can't tell if the remote is not transmitting or if the player is just not receiving the commands. I have tried holding the remote's output right in front of the player's sensor. NOTHING!!!!!!!
Any thoughts before I send the uint back?
post #835 of 1791
Okay, I just received my Panny 500 back from Panasonic warranty repair on Friday. I had the Netflix fatal issue (program failed to start) and my wifi connection on the player took a sh*t. They were cool about troubleshooting....after I explained that I followed all advice int his thread...they didn't even argue and just offered up an RMA # with instructions. So, I suspect they are paying attention here.
The replacement 500's entire interface is substantially faster than the old one. Everything works as advertised. So far I'm pleased.
I'm burning the DAC's in....again. If anything, these may be a little more crisp in the midrange than my first 500. As noted earlier in this thread by me, my first 500 had a slight-yet-noticeable difference in clarity and soundstage between it's coaxial digital output and the AC's into my Arcam AVR300. I can't tell a difference with the replacement player (a good thing). Maybe production variance...who knows. This is a good thing.
post #836 of 1791
I got a new bdt-500 BD player a week ago. Ive never had a panasonic before but thought I would try it. This player is nice but the remote control is such a flipin joke its hard to believe any engineer/product designer would let this out of the lab. what a bad joke on me. The remote has a miniature touch screen on it, hard to believe. It is so small and touch sensitive one wrong pressure point from your finger and off it goes. Try to enter the encryption code from a remote router, I dare you! Try to skim through netflix video selections with this flppin remote!!! Do not buy this. I bought this online and am not sure what it will cost to return... but I know Im not keepin even if I have to..or get to.. take it out in the back yard and stomp the craappp out of it. I will feel better.
post #837 of 1791
Seems like a minor thing to be making a big decision on.
e.g. I use the remote from my slightly old Panny 85 player with this new 500 player.
Search this thread for the single word: remote
post #838 of 1791
Fat,
"stomp" lol
post #839 of 1791
Like I wrote on the sony thread, My 790 was loud during BD playback. I could hear it from over 15ft away. The noise wasn't coming from the fan (which was quiet), but the drive mechanism.
I briefly tried a bdt220cp from costco which did not read many of the BD I got from netflix (failed to read 3 out of 5 -- they seemed to be in decent shape). it could've been a bad unit, but the bdt500 reportedly contains better components and has better build quality, so I'm gonna give it a try. My last chance before biting the bullet and getting the overpriced oppo.
post #840 of 1791
I've just about given up on playing BD's from netflix on my BDT500. If the netflix disk is in pristine condition no problem, but the slightest imperfection on the reading surface will cause my BDT500 to skip around on the disk or outright refuse to play it. Sadly I'll put the offending disk in my PS3 and it plays flawlessly. I would say easily half or more of the netflix disk don't play nice with my BDT500.
