I just wall mounted some SuperZeroes and want to hide the (in-wall rated) cable in the wall. There's no insulation so it should be no problem running the wire down from the speaker to baseboard level, where I have some plastic raceway hiding other cabling.
I'm wondering what to do behind the speaker, though. I could just drill a hole about the size of the cable and feed it through, but it seems like it would look better with a wall plate. The speakers are rather small, though, and I think a full-size wall plate would look silly.
Does anyone know of some kind of small wall plate or covering of some sort I might be able to use?
