Just did the first run of calibration of Epson TW-3200 (aka 8350 in the US) using latest AVSHD, PS3, SpyderII and ColorHCFR. After reading several reviews and people saying how well the projector is calibrated out of the box, I was surprised to end up with quite a few settings to get things right.
Here my settings - is there anything that jumps to you as odd?
Basic settings: Cinema, Iris hispeed, eco mode, skin tone 3 (default), NR off, super white off, HDMI range Expanded. I got BTB and WTW to show up, obliterated everything outside 16-235 with Brightness and Contrast.
Brightness -11
Contrast 11
Color Saturation -11
Tint -7
Color temp 7500k
Offset R -3
Offset B 1
Gain R 17
Gain B 3
Green offset/gain 0
Gamma 2.2 (default)
With this I got very good tracking of gray levels: deltaEs well below 4 from 30-100% greys, 20% was around 6. Grey was very close to 6500k, Cyan was quite close to reference, and red Y was ~21% of white Y. There are no clipped colors, and white and black points are good.
So although I had to make quite a few adjustments, they ended up really nicely. The main thing I'm concerned is whether there's something I should be concerned about with the large tweaks, or am I fretting about nothing?
I started with the color temp, perhaps I could get lower adjustments with calibrating with default 6500k - I might try that over the weekend.
edit: forgot advanced settings
Brightness -11
Contrast 11
Tint -7
Color temp 7500k
Offset R -3
Offset B 1
Gain R 17
Gain B 3
Green offset/gain 0
Gamma 2.2 (default)
My screen is actually a custom-made artists's canvas, so it was never even meant to meet any standard. It cost 105 EUR four years ago, a fraction of the cost of a proper screen, and works beautifully - but clearly is not optimal for accurate color reproduction.
