Ok, so here's the deal. I have a set of Bose Companion 3 Series II computer speakers that I'm now trying to re-purpose for use with an HDTV. The TV is a Pioneer 50" plasma. It originally came with a built-in soundbar-type thingy that looked like crap, so I removed it. It originally wasn't a problem, as the TV was in a room with my Yamaha RX-V565. But we moved and now the Pioneer is being used as a secondary TV.
That's where the Bose speakers come in. Currently, I've got the speakers hooked up as intended (the satellites to the sub, and from the sub, a stereo to RCA adapter to the TV's audio output). The problem with this is that the sound cannot be controlled through the TV, but rather by the built-in module that comes with the speakers. It's a pain in the butt having to get up whenever I want to adjust the volume. So now you have the back story, now to my real question.
The speakers have an RCA connector at the ends, so instead of hooking them up to the sub, I tried plugging them directly into the audio out on the TV. Nothing. Not sure why, maybe they weren't getting any power? Anyway, the TV also has speaker wire connectors that were originally intended for the included sound bar. If I cut the RCA plugs off from the speaker wire and plug the bare wire directly into the clips on the back of the TV, will that work? I'm assuming that, inside the insulation, there's a positive and negative wire, just like with other speakers.
The TV has a separate subwoofer connection (output?), so if I go that route, I'm thinking I can achieve a 2.1 system that is controllable by the TV's volume. As I read this, it sounds harebrained, but I'm trying to get this up and running for as little $$ as possible. Just bought a house.
Thanks in advance.
Thanks in advance.
