AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Projector HP VP6321 - very bad colors
post #1 of 10
HP VP6321 Specs
Display Type DLP
Resolution XGA
Brightness 2000 lumens
Contrast Ratio 2500 :1
Weight 3.5 kg
Fan Noise 36
Lamp Life (Typical) Up to 4000 hours
Resolution: 1024x768 (native)
Projector is connected through DVI-HDMI cable to a HDMI port on an ATI Radeon 4850 video board.
It looks like the image on a new computer without the drivers for the video board.
If I set the saturation to 0 the B&W image looks ok but with colors the actors look horrible.
Sometimes, very rarely, the projector starts flickering and it stops after I reset the projector.
Please help me repair my projector.
post #2 of 10
I have tried to connect to the projector with my notebook with a VGA-VGA cable and it works perfectly.
But I can not change the cable for my computer, the dvi-hdmi cable right now.
post #3 of 10
Try a new cable...it looks like that is the problem - not the projector.
post #4 of 10
After 30 minutes on the VGA cable the picture suddenly returned to the horrible image as in my first post. I have used a different computer for the vga cable so it is not the computer or the cable for sure.
What else could it be?
post #5 of 10
Any other ideas? I would like to buy a new lamp but I am not sure this is the problem.
post #6 of 10
I don't think a new lamp would help. The projector is not worth the cost of a lamp. I have an old VP 6120 that has a great picture and works great but has over 3000 hrs on the lamp and I can't give it away no one is intrested. Look on ebay for 1024 x 768 projectors and you'll find many for less than the cost of a lamp.
post #7 of 10
Definitely NOT the lamp. The lamp would NEVER cause these problems.
post #8 of 10
I am ready to try my luck and open the projector for adjustments. I just need a hint what could cause this kind of problems. I tried to watch some TV show through my receiver and same problem so the problem is for sure coming from the projector.
post #9 of 10
There are NO adjustments to be made inside the projector. There are only connections, but this does not look like a connection issue. This appears to be a problem with the image processor. not something you can repair. But, you can go in and see for yourself.
That projector is about 7 years old, looks like it's time to replace it. Sorry.
Edited by Sheridan1952 - 2/9/13 at 6:13am
post #10 of 10
good idea,Look on ebay for 1024 x 768 projectors and you'll find many for less than the cost of a lamp. 10.gif
