Hi...
I am trying to help out my brother in law get a projector setup to work outside by the pool to watch mostly sports, but also other stuff over his cable connection. Its a basic projector that I believe has DVI/HDMI input as well as component video. I can get the model number if it helps.
He has Comcast for cable and was curious if anyone has ever done this or has recommendations. Here are a few questions I have:
- Is it possible to run coax outside and get this to work with the projector with a tuner box and do I need a Comcast cable box to get this to work? Something like an standalone Hauppauge box?
- What does Comcast use for modulation? QAM? Soemthing else?
- If I do need a cable box, is there something cheap I can buy or do I need to purchase/lease through Comcast?
- If I need the cable box, can I run the output from a box inside and send video/audio over ethernet, coax, other using a encoder or something? I wouldnt want to run HDMI for 100ft. If this is the only solution, then I guess I would change channels remotely using an RF extender or something but would be open to suggestions.
- Any other suggestions?
Werner
Werner
