Several years ago I used to troll around on the AVSforum as I was learning about plasma displays, scalers, DVRs, etc. But what I've always really wanted was an HTPC that did the things I needed in one box. A week ago I ran across a link to the SiliconDust site and then I found information about the FCC requiring over the counter access to CableCards. So now it's on!
I've tried to come up to speed on Ceton, SiliconDust, Media Extenders, etc. Mostly by reading some of the longer information laden threads here on the AVSforum.
I've reached a point where I need some direction. I've got four displays in my house, 3 driven by BrightHouse DVRs (Cisco) and one with a Tivo Series3 (Lifetime) and an Xbox360 for games. The Tivo and Xbox are local to that display (70" DLP) while the other displays are all driven from a central closet using Knoll baluns ... two HDMI and one Component.
When I had my house built, I went a little over the edge and I had two cable bundles run to each room. Each bundle has 2 CAT5e and 2 RG-6QS in it and they all come back to a central room where I keep my servers, router, DOCSIS modem, switchs, AP, etc, all in a 19" rack.
In most cases, my displays are flat on a wall with little space behind them so that's why the cable DVRs are all remotely located in the media closet. The Knoll baluns backhaul the IR signals so I'm good there.
But as I noted above, I have BrightHouse and I hate them. I hate paying $21/month for each DVR that doesn't talk to any of the others. I hated that they would roll a truck just to install a CableCard in a Tivo and charge you for the fact that it took the tech days to get it done. I could go on, but I suspect many of you know what I mean.
So I'm quite positive that I want to put together an HTPC running MCE under Win7 64-bit. And I know that I'll either use the Ceton PCIe card or the SiliconDust HDHRPrime. I would lean toward the HDHRPrime because there are a couple of iPads in the house that could benefit from being able to allocate a tuner over the wireless network now and then.
So here's what I don't fully understand. Why do I have to use a Media Extender to drive displays other than the one hooked to the main HTPC? Why can't I install a couple of dual port video cards in the HTPC with HDMI on them and drive my four displays ... 3 over baluns? I'm sitting in front of a Win7 64-bit system at work with 4 19" displays driven by a pair of NVidia cards in the machine and it works well.
If I can drive all 4 displays from the HTPC, can I enable 4 incoming IR ports where each controls a specific display?
With the announcement of the Ceton extender (versus getting an old Xbox) I see this as less of a problem. I can put the HTPC and 2 extenders in my media closet and direct the backhauled IR to each of them. I would just drive the fourth display using the Xbox that's already sitting next to it. But I'm curious as to why a multi-display setup isn't done on MCE under Win7. There must be some issue with MCE itself that won't handle the multiple displays and multiple inbound IR control signals.
I don't do 1080p, 5.1 or 7.1 audio, or anything else particularly demanding. Maybe there's something I'm not seeing, like perhaps there are no video cards with dual HDMI on them ... only dual DVI.
What say you, is a 4 HDMI out / 4 IR in HTPC possible or am I better off going with the flow using one HTPC and 3 media extenders?
