AVS › AVS Forum › Audio › Speakers › flush L / R / C speakers
post #1 of 4
looking to get rid of my onkyo 6200 HTIB basically. bought 4 SNELL OH-S7 for my ceilng, looking to put something similar around the wall mounted tv.
are these Yamaha's from amazon decent ?
also, would i just buy the 3-pack and use the 3rd as a center speaker, or should the center have different specs ? i'm not sure i can mount that center speaker sideways given the center-position of the tv. it would run across a stud due to it's width, so would need something slimmer width wise
or if anyone can point me in the direction to some decent speakers, within a decent price range, i'd appreciate it
post #2 of 4
you may be under estimating the number of studs that are in the walls around the windows as well. this can be a tricky install. I prefer the Polk OWM series for this kind of install.
post #3 of 4
Look for on-wall LCR speakers, and then they can match, which is more ideal. A horizontal center in not a deal-breaker, though.
Maybe Definitive Technology Mythos?
post #4 of 4
I would look at NHT on-wall speakers, and the Absolute center
http://www.nhthifi.com/Home-Theater-...&category=7166
http://www.nhthifi.com/Absolute-Cent...&category=3774
  Back to Forum: Speakers
