Hello,
I am using an Acer laptop computer connected to a Toshiba LCD flat-screen TV to watch shows streaming from Netflix. Because the computer doesn't have an HD output, I use a VGA cable to connect the computer to the "PC" port on the TV.
The picture and audio quality are fine, but I haven't been able to figure out how to fill the TV screen. There is a wide, black band framing the image.
The TV has several options to enlarge the image; I often use them, such as to enlarge the image when watching wide-screen movies on the Turner Classic Movie channel.
But the TV's enlarging options (e.g. Widescreen 1, Widescreen 2, etc.) are grayed out when using the TV's PC input option. Is there a way to fill the wasted real estate on the TV without distorting the aspect ratio?
Bill
Bill
