For both aesthetic and usability reasons, I want to put my turntable on a wall mounted glass shelf (see below). However, the glass is going to pick up vibration while playing music. So, what I think I’m going to do is still mount it on the wall, but put two layers of 1/2 lbs. mass loaded vinyl (it’s THE sound proofer of choice) I have left over under it, and then mount the turntable itself on sorbothane hemispheres. I can also put a mass loaded vinyl layer between the glass shelf and mounting arm, and another one between the wall and mounting arm. Considering the shelf itself is mounted to a wood stud, I think this would actually provide a good level of vibration isolation, even better than what I have now. What do you think?
glass shelf:
http://www.amazon.com/gp/product/B00...00_i00_details
mass loaded vinyl:
http://www.soundproofingamerica.com/...aded-vinyl.asp
sorbothane hemispheres:
http://www.amazon.com/Bright-Star-Is...6479114&sr=8-4
glass shelf:
mass loaded vinyl:
